What can $320 and about 10 hours of time get you?
   / What can $320 and about 10 hours of time get you?
TDVT, an FYI. As usual with me, after I go through too much work I find a shortcut. I was at TSC (Tractor Supply Company) and saw some sleeves for 1 inch rod. If you don't have a TSC in your area your local tractor dealer probably has some sleeves also. This would have saved me having to drill then grind the short pieces of tubing to fit the 1 inch pins. The sleeves I'm referring to have a hole drilled and tapped for a grease fitting but you could cut and use both ends anyway. They even have different lengths available. The schedule 80 tubing was still cheaper but if you don't want to have to do the fitting, the sleeves are the way to go.
BTW, keep us posted on your build.
That is pretty much the same thing as I saw.
It was in a another thread that we both posted in.
THREAD
Thanks for the Kubota-version pics. I think I've got a plan.
I guess I should have looked at those pictures a little closer. I thought that was a Kubota Quick Coupler instead of an ATI unit. I didn't know they made one like that. Makes me wonder who copied who...lol.
   / What can $320 and about 10 hours of time get you? #23
Just throwing this out as an FYI to those fabricating their own projects...
Another option to pipe is to buy chromolly tubing as it comes in a variety of size and wall thickness. It typically does not have a welded seam running on the ID that sometimes impedes on the ID too much like pipe or some of the lesser grades of tubing.
Unlike pipe, tubing is sold by OD and wall thickness and it is fairly easy to get the desired ID. Example: 1.125" OD and 0.058" wall will yield an ID of 1.009".
Thanks for that tip. Unfortunately, my local steel supply warehouse doesn't carry chromolly. I only had to drill out 8 short pieces so it wasn't really that big a deal. If in the future I need lots of pieces, I'll remember your tip. I looked at the option of getting a local machine shop cut and turn the pieces I needed and it wouldn't have been that expensive but they were running 3 weeks out. I didn't feel like waiting that long.
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2012 Jeep Compass SUV (A48082)
2012 Jeep Compass...
2014 Chevrolet Impala Limited Sedan (A48082)
2014 Chevrolet...
Harper SB1300 Straw Blower with Hose (A51039)
Harper SB1300...
2022 Club Car...
