What Brand/Type chain should I buy?
   / What Brand/Type chain should I buy? #41
Husky is a good brand. But dont be fooled. They make lesser models to meet lower price points and they just arent the same. Stihl does the same thing
Yep, best to educate yourself on all the different models. That's why I mentioned the other models above.
   / What Brand/Type chain should I buy? #42
Hey bluegill2 the 455 rancher should be all I need! the 555 looks good also but the price is to high.
   / What Brand/Type chain should I buy? #43
There is nothing wrong with a saw that is a non pro saw especially for a homeowner. A non pro saw is usually bigger, heavier, and less powerful than a pro saw with the same size engine. A pro saw will run forever, a mid range or occasional use saw should do a lot of running. I have 4 pro saws and one occasional use saw. I love the occasional use saw. It is great for cutting up something small or limbing a tree. One of the next saws I want to get is a mid range use saw. I plan on building it so it will out cut a pro saw of the same size.
   / What Brand/Type chain should I buy? #44
Yes Jack, it should and isn't a bad saw. The 555 is more saw, so it's expected to be more money. Compare the 455 to the 545.
   / What Brand/Type chain should I buy? #45
if you buy the 455 rancher, Only buy with a 18'' bar if the chain is 3/8 . I have an old rancher 20'' 3/8 chain ,and it's all my rancher wants
   / What Brand/Type chain should I buy? #46
Back to the chains for a minute, I have a mystery that maybe someone here can help me with. I have a Stihl farm boss 290 and have been using Stihl safety chains with it for a while. I saw some new Oregon, non-safety chains on sale and bought several. They said they fit my saw. Yesterday I put the new chain on and within 10 minutes the front roller froze up on my bar. In addition, the chain was stuck a bit when I pulled it off the bar. I switched bars and again, a freeze up. I freed the rollers with WD40 and switched back to the Stihl chain and had no problems. Then I tried the Oregon chain again and loosened it up a bit on the bar and it worked OK. Any comments would surely be appreciated. I have a lot of firewood to cut before snow flies. The oiler doesn't put out a ratio of 1:1 vs a tank of gas. Could that be the problem? The bars are fairly new. Other than this I can't figure out what's wrong. I did notice that on the Stihl chain, there was a hole in every link and on the Oregon chain there was a hole every other link?
   / What Brand/Type chain should I buy? #47
Can you still see the size markings on the side of your bar (towards engine) and do they match the new Oregon chains?
   / What Brand/Type chain should I buy? #48
Yes, and the markings on the bar and those on the chain box are identical. .325, 1.6mm, 0.063", 67.
   / What Brand/Type chain should I buy? #49
Stihl is notorious for tuning their bars/chains for minimum oil usage, perhaps in response to EPA problems. I've two "USA" model 660's which I put high output oilers on so I could safely CSM without an auxillary oiler. The same saws are sold in Australia with the high output oiler's as default.
I don't know if they sell a high output oiler for the 290. You might need to stick to Stihl chain if you can't up your oil output.
   / What Brand/Type chain should I buy? #50
I went to a Stihl dealer today, and got some answers. The Stihl chain has a grove in the side of the links as well as a hole in the bottom of every link. The Oregon chain is flat on the side and only has a hole in every other link. If what newbury says about Stihl's oil output being minimal, then I can see where the Stihl chain would move the oil along the bar more efficiently than the Oregon chain. The Stihl chain is $2 more, but I guess it would be worth it to keep the bar oiled. I found that if I ran the Oregon chain a bit loose, I didn't experience any freeze up, but I also bought a Stihl chain. Better safe than sorry. Mystery solved, I guess. :confused3:
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
John Deere 5075E (A53317)
John Deere 5075E...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A55314)
2023 Kubota L3560...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
