Item Details
- Auction ID
- 55314
- Make
- Kubota
- Type
- Ag Equip
- Year
- 2023
- Auction House
- Fastline Auction, LLC
- Model
- GL350
- Location
- North Carolina
- Horsepower
- 37
Description: The Grand L60 boasts a wide range of deluxe features and functions to reduce fatigue and maintains productivity. With reduced noise and vibration levels, an improved deluxe seat, power steering and a cup holder, you can rest assured that your comfort comes firstso much so that you might forget youre working. The Grand L60s engine lineup has been redesigned for cleaner emissions and outstanding fuel economy. Common Rail direct injection is employed to deliver greater fuel savings and lower emissions while maintaining a high level of power and torque. GST (Glide Shift Transmission) Kubotas exclusive GST features 12 speeds and clutchless operation for maximum operator ease. And, thanks to its electronically controlled hydraulic shifting system, the Grand L60s GST allows you to shift on the go with exceptional response. A. FRONT LOADER HYDRAULIC VALVE Kubota has designed an integral Front Loader Valve as part of the tractor. With this valve, you can quickly and easily attach the front loader and other front-mounted implements. The valve promotes efficient, clutter-free operation and matches the sleek styling of the tractor. If you dont require a front loader or other front mounted implements, an optional Diverter Kit is available to allow the loader valves to function as rear remotes. B. LIVE-INDEPENDENT PTO The hydraulically activated Live-independent PTO clutch allows both the rear and mid-PTOs to be independently engaged/disengaged while the tractor is still in motion. And because the levers located in a convenient position, activating the independent PTO is easy. In addition, a Neutral/Auto Shut-off system and protective flip-up shields are included for total PTO safety and productivity. C. TELESCOPIC LOWER LINK ENDS A wide range of implements can be used with the 3-Point Hitch. Quick and simple hook-ups can be achieved via the standard-equipped telescopic lower link ends. The front loader can also be used with the mechanical or optional hydraulic quick coupler attachments, such as buckets, pallet forks and bale spears. Simple to attach and detach, these handy functions dont require the use of tools, saving time and effort. Year: 2023 Make: Kubota Model: L3560 Serial No.: KBUL5AGRAP8F56245 Hours: 5.0 Meter Reads: 4.7 Engine: D1803 Engine Manufacturer: Kubota Cylinders: 4-Cyl. Horsepower: 37.0 Transmission: Power Shuttle Drive: Mechanical Front Wheel Drive (MFWD) Front Tire Size: 7.5-16 R1 Rear Tire Size: 12.4-24 R1 Stock No.: E79289 FASTLINE SALES REPRESENTATIVE(s) Nick Herring nick.herring@fastline.com 919-922-2854 Item Location - Address: Provided by Seller Item Location - City: Greensboro Item Location - State/Province: North Carolina Item Location - Postal/Zip Code: 27405 Item Location - Country: United States
This is a online bidding auction by Fastline Auction, LLC
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader
see lot description, multiple locations, KY 40010
Starting Bid: 14000.00 USD
Auction Finishes: November 04, 2025 at 04:52 PM
Click Here To Bid Now!
Happy Bidding!
Happy Bidding!
