What battery for a 3015?
/ What battery for a 3015? #1
UpNorthWi
I find myself needing another battery for my Mahindra 3015. Does any one know what fits and have a suggestion for a decent brand with a warranty? I'm in SE Indiana and everything here seems to be an off brand with only a year warranty. The old battery was a Exide that I believe had a 5 year warranty, but Exide no longer lists Mahindra.
/ What battery for a 3015? #2
Well, I did a quick & dirty web search and could not find a replacement either(looking for your group number). Sooo - - two options; take measurements of OEM battery - height, width & depth OR just take the old battery to a local battery outlet and have them match it up to what they have. I currently have an Odyssey battery in my Kubota - I like AGM batteries, they seem to last longer. Exide is a good brand - - don't worry that Exide doesn't list them any more - go with the biggest battery with the highest CCA(cold crank amps) that you can stuff in the available space. If you have an Exide dealer take it to them.
/ What battery for a 3015? #3
Take the battery with you and get an interstate. You will need the core with you anyway so will end up being the easiest
/ What battery for a 3015? #4
Get an OPTIMA battery and you'll never have to worry about leakage or a lack of power. Mine was shipped to my house, and my local recycler gave me $10.00 for the old one. Here's where I bought mine. Optima Batteries Redtop 34 78 Starting Battery 12 Volt 8004 003 | eBay
Optima Model 75/25 Red Top Battery: The Optima model 75/25 has both top and side GM-style terminals. It features Optima's patented SpiralCell construction. Optima Red Top batteries offer exceptionally high peak discharge capability for fast engine turnover the instant you hit the ignition.
Hot and cold weather performance is enhanced by extremely low internal resistance, and the Optima Red Top battery boasts a shock and vibration resistance rating 14x higher than conventional batteries.
Optima batteries will operate without leakage when mounted in any position, and they do not off-gas in normal operation. That means that corrosion at the battery cable connections and elsewhere under the hood which is normally caused by drifting acid fumes, is eliminated. The Optima Red Top battery is maintenance free and holds a charge longer than other batteries during periods of non-use
FUEL TANK WITH PUMP AND HOSE (A68842)
FUEL TANK WITH...
YALE FORKLIFT (A63291)
2023 USA Manufacturing Hydraulic Thumb Excavator Attachment (A66734)
2023 USA...
JOHN DEERE 6330 TRACTOR (A65057)
JOHN DEERE 6330...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
