Grading What attachment to tackle brittle old asphalt
   / What attachment to tackle brittle old asphalt #11
Teeth on a backhoe or excavator bucket. Pound it into pieces then scoop it up and load in a dump truck/trailer.
   / What attachment to tackle brittle old asphalt #12
PTO rototiller running in the direction to lift up the chunks. Wait for rainy weather to keep the dust down. I wore down he teeth a bit but they needed to be replaced anyways. Ignore the noise.
   / What attachment to tackle brittle old asphalt #13
I'm wondering - - PTO driven rototiller. Will it chop up those larger chunks of bonded asphalt such that the chewed up surface can simply be graded and rolled smooth. Seems to be a real bummer if you would loose the value of all that old asphalt.
   / What attachment to tackle brittle old asphalt #14
Hey bud,
I've done exactly what you are pondering - box blade and old asphalt. If you have a smaller tractor then you can just lower one or two rippers on the box blade to get a smaller bite. Get a tip of the ripper up under the asphalt (might take a few tries/passes) then you'll be off to the races. It'll peel right up quite easily, most likely. Then as soon as you can, switch to the loader to start scooping up bigger pieces. Ideally you would break up the asphalt and re-use it after you re-graded the substrate.
Good luck!
   / What attachment to tackle brittle old asphalt #15
You just need one of these:
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
Stanley hydraulic power pack (A56435)
Stanley hydraulic...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56435)
Neckover GL24-2-7K...
JOHN DEERE 333G SKID STEER (A52709)
JOHN DEERE 333G...
