Grading What attachment to tackle brittle old asphalt
   / What attachment to tackle brittle old asphalt #11
Teeth on a backhoe or excavator bucket. Pound it into pieces then scoop it up and load in a dump truck/trailer.
   / What attachment to tackle brittle old asphalt #12
PTO rototiller running in the direction to lift up the chunks. Wait for rainy weather to keep the dust down. I wore down he teeth a bit but they needed to be replaced anyways. Ignore the noise.
   / What attachment to tackle brittle old asphalt #13
I'm wondering - - PTO driven rototiller. Will it chop up those larger chunks of bonded asphalt such that the chewed up surface can simply be graded and rolled smooth. Seems to be a real bummer if you would loose the value of all that old asphalt.
   / What attachment to tackle brittle old asphalt #14
Hey bud,
I've done exactly what you are pondering - box blade and old asphalt. If you have a smaller tractor then you can just lower one or two rippers on the box blade to get a smaller bite. Get a tip of the ripper up under the asphalt (might take a few tries/passes) then you'll be off to the races. It'll peel right up quite easily, most likely. Then as soon as you can, switch to the loader to start scooping up bigger pieces. Ideally you would break up the asphalt and re-use it after you re-graded the substrate.
Good luck!
   / What attachment to tackle brittle old asphalt #15
You just need one of these:
MERITOR SEMI TRUCK REAR END (A57192)
MERITOR SEMI TRUCK...
2002 X-L100HDG 40ft 50 Ton Tri-Axle RGN Lowboy Flatbed Equipment Trailer (A55852)
2002 X-L100HDG...
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
2016 Peterbilt 597 Wet Kit Tri-Axle Day Cab Truck Tractor (A55852)
2016 Peterbilt 597...
Case IH Maxxum 150 (A53317)
Case IH Maxxum 150...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Bus (A55852)
2000 Thomas Built...
