Grading What attachment to tackle brittle old asphalt
   / What attachment to tackle brittle old asphalt #1
NewHollandaise
New Holland t1510
Hey, Im a newbie tractor owner and im not sure what attachment to use for a job on my driveway. I have patches of old brittle asphalt that Id like to remove. Wondering if a box blade is a proper implement for the job? Ill upload a picture and hopefully get some advice!!
   / What attachment to tackle brittle old asphalt #2
I would dig them out with a shovel and put them in the FEL. If they’re really big, i’d use a backhoe.
I’m not sure what good dragging a blade over them would do except for knocking off the high spots.
   / What attachment to tackle brittle old asphalt #3
A box blade might work if you can lower the scarifiers enough to rip up the patches. Are you wanting to remove all the old asphalt or just some small patches of it. If just a small area so as not to disturb the remainder, a backhoe might be best.
   / What attachment to tackle brittle old asphalt #4
:welcome:
To the forum NewHollandaise. We are glad that you joined.
As Gary pointed out, a little more information on what exactly you want to accomplish would really help.
   / What attachment to tackle brittle old asphalt #5
If it's old deteriorated asphalt box blade & rippers work with small tractor. You might also be able to get the loader cutting edge under the asphalt and peel it off.
If you have to purchase a box blade try the bucket first.
   / What attachment to tackle brittle old asphalt #6
Welcome to TBN.
Have you been at this property long enough to know it is/was a paved drive?
To me, your pic looks like millings and not an old paved surface, and that's pretty typical of what they look like. Tight packed areas with loose, gravelly areas as well.
   / What attachment to tackle brittle old asphalt #7
My FEL and Backhoe made mince meat out of my driveway and with no teeth on the FEL
Once you hook it it all breaks up pretty easy.
At least mine did and I did not want it too at the time.
   / What attachment to tackle brittle old asphalt #8
I use my forks to break it up, then scoop it up with FEL.
I壇 like to remove all the old asphalt chunks so that I can box blade the entire driveway and try to smooth it out. It seems brittle enough that the teeth would rip it up. Thanks!
   / What attachment to tackle brittle old asphalt #10
There is a video on YouTube:Tarter Extreme Challenge Part 2: Tiller. They use one of their tillers to chew up old asphalt. Some of their videos are hilarious, they do some outrageous things with their equipment.
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
Allis Chalmers Disk (A50515)
Allis Chalmers...
Excavator Mulching Head (A50774)
Excavator Mulching...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2013 Nissan Sentra (A50324)
2013 Nissan Sentra...
2025 GIYI Single Cylinder Hydraulic Grapple Stump Bucket Skid Steer Attachment (A50322)
2025 GIYI Single...
