What attachment suggeston
   / What attachment suggeston #11
That yardtool has me interested. I see it is basically a non-powered version of a power rake.
a power rake looks awesome, and if I found a good deal on one I would buy it in a heartbeat. How close does the yardtool come?
I can see where it would be easier to smooth with than a box blade because of breaking up the existing great.
my interest is peaked.
I have one of these that I use to drag our riding arena (which is sand). If you look at the picture, you'll see I made a scraper blade to clean off the sand when it's wet/damp. Without it, it would build up until the nubs were gone and then the roller wouldn't roll well. Only a problem when sand was wet but since I still drag then I had to modify it. I wouldn't use it as a primary tool to rip up hard pack because you CAN bend the teeth if you catch a rock AND it's not designed to go down really deep anyway. But if you have a somewhat loose base that you want to smooth, level and pack some it will work well.
I think it works best in dryer loose soil that you are trying to prepare for seeding or for dragging riding arena's like I use it for. It does NOT work well on material with large rocks (fist size or larger) since when the roller hits the rock, it rdies up and over it, lifting the roller up and leaving a hump of material until the roller comes back down. Hope this helps.
PS I bought it new for $1100, 6 foot wide
   / What attachment suggeston #12
Found a cheaper price if anyone else is looking - $891 with free shipping for same 6 ft size and better pictures of the yard tool here.
I watched the video of it in action, does anyone else think it will do the intended job?
   / What attachment suggeston #13
They look like they have 3 different models. The cheaper ones are lighter duty and have smaller spiked rollers. (Mine weighs 750lbs). The one shown in the video looks like it has heavier duty scarifiers than mine (a good thing) but a smaller diameter ie lighter, roller. They also make a second roller as an option so you can have one roller right behind the other.
   / What attachment suggeston #14
I have a front-end loader and box-blade and plenty of fill dirt available in different parts of the yard.
Well I think you're golden with that combination...unless you have money to burn. Sure you're not going to do it in a day but so what?
   / What attachment suggeston #15
I would agree with savageactor7. Use what you have.
A landscape rake is what I used for re-grading, but the box-blade should work ok.
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
2011 Chevrolet Impala Sedan (A59231)
2011 Chevrolet...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A56438)
Bulk Lot of NEW...
YANMAR VIO355 UNIVERSAL EXCAVATOR (A60429)
YANMAR VIO355...
Wolverine Quick Attach Post Hole Digger w/ Augers (A59814)
Wolverine Quick...
2016 Toro Workman HDX-D Diesel Utility Cart (A59228)
2016 Toro Workman...
