What are you using to lube your implements and tractors?
   / What are you using to lube your implements and tractors? #1
Yander
Ohio
Yanmar SA425 - Kubota G6200 GT
What is working well for you? I've been working on PTO shafts, sizing, cutting and lubing since I've bought some new equipment. I've always just used grease but is there something that works for you that may be better.
Also, I've been spraying fluid film on all exposed, unpainted, surfaces of my tractor. Anyone else using something else?
   / What are you using to lube your implements and tractors? #2
https://media.tractorsupply.com/is/...g&qlt=100,0&resMode=sharp2&op_usm=0.9,1.0,8,0
   / What are you using to lube your implements and tractors? #3
Different greases for different equipment.
But I heartily endorse your use of fluid film. I've tried to spread spray cans of it throughout my 5 "shops" so whenever I see bare metal I get it covered.
It seems in Mississippi rusting is a form of waste disposal.
/edit - also try to give a squirt for nuts and bolts, locks and latches.
   / What are you using to lube your implements and tractors? #4
Each of my hay tools have a tool box on them and each tool box has a cartridge lever type grease gun inside for field use and no I don't use Tractors Supply grease, I use Mystic JT8 grease in them.
   / What are you using to lube your implements and tractors? #5
I’m also a fan of fluid film for bare metal and to prevent rust. I’ve also used a spray on lithium grease some instead of regular grease. I use this on things like pto shaft connections. It’s thicker than WD40 but thinner than regular grease.
   / What are you using to lube your implements and tractors? #6
WD 40 is NOT a lubricant. It's a moisture dispersant and has no long term lubricating qualities. Besides, it stinks....lol I use Fluid Film on my battery terminals and that is about it.
   / What are you using to lube your implements and tractors? #7
I guess you use mistic jt6 which is grease, jt8 is heavy duty oil, as I remember, but I might be wrong.
Actually, imo, any grease works as long as you use it regularly. The moly or lithium gives additional level of protection.
On metal parts I use same heavy duty or rad grease, whatever I have in hand when i see something asking for attention. I think grease stays longer and provides better protection.
But for each his own.
   / What are you using to lube your implements and tractors? #8
You are correct at least in my implement grease guns. For general greasing I have an ARO air greaser with a 150 foot hose on it and I use Lubrication Engineers teflon fortified grease in 150 pound open head drums. Not cheap but really hangs in there. Last 150 pound drum I bought (from my jobber) was 1500 bucks. Lasts me a couple years.
   / What are you using to lube your implements and tractors? #9
Lucas green HD tractor and equipment grease
I try to use a good quality Grease I don't have a specific brand that I use. I'm sure there are different quality but as mentioned any Grease is better than none.
I've been using Lucas mostly. I just used grease and a little bit of fluid film on the PTO shaft that I was working on yesterday.
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
2016 Ford E-450 LP Handicapped Bus (A53422)
2016 Ford E-450 LP...
2016 Ford Fusion SE AWD Sedan (A53424)
2016 Ford Fusion...
183 (A52705)
183 (A52705)
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
2015 Ford F450 SD Flatbed (A52377)
2015 Ford F450 SD...
