What are these things?
/ What are these things? #1
Indian Territory
New Holland PowerStar 75
Just for curiosity sake, can someone help me out? These remote valves on the back of this tractor I can't afford appear to drain to small reservoirs below. (Or is that an uptake?) What am I looking at? I've never owned a machine that had them. Tractor is a New Holland T6.160.
Edit: Looks like I got my arrows mixed up, but you get the idea.
/ What are these things? #2
These are reservoirs for collecting oil drip from rear hydraulic couplers.
/ What are these things? #3
I had those covers on my old 5310. I actually installed them myself. I didn't use the reservoirs but those ends work really well at collecting the fluid runoff and keeping dust and dirt out.
Ah cool. Makes sense. They do get grimy.
But why just two reservoirs for three valves? A smaller tractor I'm looking at has two valves but only one reservoir. Why always one fewer?
/ What are these things? #5
The setup pictured has 3 remotes the tractor is available and quite commonly equipped with four with 2 remotes on each side with the little catch bottles on each side the lines do not need to cross the rear of the tractor. They usually only survive for a few years then the drips act as a rust and corrosion preventer.
/ What are these things? #6
Not something I'm interested in and never would be because hydraulic fluid drips are easily removable with a quick pressure wash and some proprietary car wash solution. I use Chemical Guys myself in a foam cannon. My Pioneer couplers all drip with every decouple and a couple and decouple a lot so I keep an eye on the fluid level and add when required. Never seen any 'catch reservoir' on any farm tractor before.
/ What are these things? #7
They have been around for quite a few years.
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
213086 (A64276)
213086 (A64276)
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
1990 John Deere 755 (A64119)
1990 John Deere...
1995 48ft. 38 Ton T/A Flatbed Trailer (A61573)
1995 48ft. 38 Ton...
