What are these? (can't find them in manual)
   / What are these? (can't find them in manual) #1
TSO
Elite Member
SouthEast Michigan
Massey 1652 HST Cab
Really gave my rig a good "once over" when I serviced it, and noticed these... Anyone have a clue as to what they are?
This one flips to the left
This one looks to be attached to a lever & spring, but I can't figure out what it does.
   / What are these? (can't find them in manual) #2
The flip lever 'bypasses' the draft control
the other linkage is what actually controls the draft control.
Basically, if you dont want to use the draft control for a 3pt implement, put the flip lever in place. Otherwise, the toplink pulls on the other linkage and will lift your implement based on where the draft control lever is set. It is mostly for ground engaging attachments like a plow.
   / What are these? (can't find them in manual) #3
I couldn't figure out how the draft control worked when I first got my tractor, till I realized it was locked out! The manual was a bit confusing.
   / What are these? (can't find them in manual) #4
Ya, me too! Still messing around with that function. The manual is almost useless for info on draft functions.
   / What are these? (can't find them in manual) #5
with the 2 bottom 14" plow I used this year, I basically set the draft lever all the way down, and the 3pt all the way down, and hit the 'road' in 2nd gear mid range... plowed great!!
   / What are these? (can't find them in manual) #6
When you say "put the lip lever in place" do you mean vertical, or angled to the left?
   / What are these? (can't find them in manual) #7
I think the metal rod ends up pointing straight up. Basically when you flip it into place, it prevents the toplink from activating the 'sense linkage' for the draft control.
TSO's first picture shows it 'in place' for no draft control function.
Basically the draft control senses how hard something like a plow is pulling. And will lift it up out of the ground when you hit something like a rock. the control lever next to your 3pt lift control, will set how quickly it responds.
   / What are these? (can't find them in manual) #8
I think I'm tracking with you. I've tried to figure out the draft function, but had no idea it was locked out!
   / What are these? (can't find them in manual) #9
For the most part, its not really needed. Only use I have for it is plowing...
   / What are these? (can't find them in manual) #10
I have actually used it while using my box blade. With the draft engaged, if the BB starts digging too deep, it will raise up a bit!
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2013 FORD F250 (A60460)
2013 FORD F250...
2022 CATERPILLAR 249D3 SKID STEER (A60429)
2022 CATERPILLAR...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
2017 Ford F-550 (A55973)
2017 Ford F-550...
2017 Ford F-550 Service Truck (A59230)
2017 Ford F-550...
