shooterdon
Super Member
- Joined
- Nov 24, 2012
- Messages
- 5,278
- Tractor
- 2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
House is 65-75% wood heat and balance is propane. I used to head my workshop, but it got too expensive
One thing I learned about propane that I did not know from the HVAC folks that replaced our old Bryant condensing furnace with a new Bryant Plus 95 was that propane is hard on the burners where as NG isn't. Propane tends to leave deposits in the burner tubes that eventually upsets the air to fuel ratio and causes them to burn rich and causes the secondary heat exchanger to plug up which is what happened to our old furnace. I said hw so to the tech and he showed me when he pulled the burners. You could readily see the carbon that had built up on the heat exchanger and the flame roll out switch was also tripped. They told me I need to replace them about every 3 years if the furnace was the main source of heat (which it isn't) so I set it up for replacement every 6 years. Not that expensive either (burners) either, like 50 bucks each. Better than having to replace the entire furnace because the secondary HX is plugged with carbon.House is 65-75% wood heat and balance is propane. I used to head my workshop, but it got too expensive
Never measured, but I'd guess ~15', maybe a bit longer. Last time I bought it (couple years ago) it figured out to ~$110/cord.What is log length? How much do you pay for a load?
Woodstove heats my place better than the furnace, especially the upstairs. Furnace is FHA, with ducts only on the 1st floor (house is approx. 200 yrs. old, and no easy way to get ducts upstairs). Heat coming out of the ducts is only 100° or so (just barely feels warm on your hand), and it's just not hot enough to rise up the stairway. Woodstove much hotter.When I'm around, I heat mostly with wood with a single wood stove in the center of our open floor plan home. (The bedrooms upstairs open onto a balcony hallway running above the wood stove, so leaving their doors open heats them as well.) Our home is very well insulated and sealed. Even so, it's surprising how well a 40,000 BTU stove can heat the place. It won't keep up if the outside temperature is well below 0˚F, but we can stay quite comfortable otherwise.
in our house dressed normally.
H,mm you pre ought propane for $1.99 here in michigan? Hell of a deal since the cheapest price I found was $2.45 and we are not that far from each other.What company did you purchase from?I'll start it off by saying we heat with propane (Bryant Plus 95) for the house and in floor PEX (propane fired hot water heater in the shop, but we also heat with 2 biomass stoves, one in the house and one in the shop.
We burn primarily dried off grade seed corn (which I get for free) plus processed wood pellets. I mix the corn and pellets together and the stoves burn them
Each stove is capable of 80K Btu output though I rarely run them flat out and about the only time the central furnace comes on is when the heat load exceeds the output of the stove in the house. I do keep my in floor PEX system active all winter and hold the slab temperature around 60 degrees, I like warm feet when working in the shop.
My total biomass fuel bill is around 600 bucks (for processed wood pellets) during the winter and I usually consume one 500 gallon bottle of propane as well.
I pre bought propane this year at $1.99 a gallon and glad I did as propane here is at $265 a gallon presently and going higher.
Where are you at concerning heat and what do you use for fuel?
