George2615
Super Member
At what point would you call it 'over kill' ?
To be safe hauling your 5K load you should use 4 grade 70 3/8" chains and binders. Two in front, two in back.
Legally for loads under 10K you only are required to use one in front and one in back. When securing a load like this on a trailer I believe more is better and safer.
Willl, you didn't copy my entire quote. I said only 2 tie downs are required by the law but to be safe he should use 4. This is what I mean by more is better.
I wouldn't call 4 tie downs overkill. If you want to tie down a 5K load on your trailer with the minimum tie downs required you can do so. I choose to avoid doing things that way.
