What am I going to need to secure my Bobcat to my trailer?
   / What am I going to need to secure my Bobcat to my trailer? #1
dieselfuelonly
Chapel Hill, North Carolina
Yanmar YM1401D
   / What am I going to need to secure my Bobcat to my trailer? #2
Dennis, DOT wants to see a chain and binder on all four corners.
MarkV
   / What am I going to need to secure my Bobcat to my trailer? #3
It's not only the weight but you're going to have to figure travel and stopping speeds.
A 5000 lb tractor will weigh a lot more traveling at ( X) MPH and stopping.
Called FRONT PROJECTION limits.
Figuring too close to weight of the tractor is not going to work in an emergency.
While not strictly part of the trailer but worth noting is the transport chains and binders used to secure heavy equipment loads. Chain is not that large an investment; if your chain is the least suspect, better safe than sorry. Chain comes in various grades and thickness; the most commonly used chain in securing loads is Grade 70, 3/8 in., which has a 6,600-lb. maximum pull. For heavier loads, there is a Grade 70, 1/2 in. with 11,300 maximum pull.
Binders, chains, hooks and clevis pins all should be permanently marked with their capacity. If you find you need to upgrade your binders, ratchet binders have twice the strength of mechanical lever binders, and they are also much easier to tighten than the lever ones.
Whether its chains, ropes, wraps or webbing, whatever secures the load must comply with the Federal Motor Carrier Regulations regarding the Aggregate Working Load Limit. The basic requirement is that tiedowns must have the combined strength equal to at least 50 percent of the load being secured.
The way to calculate the aggregate load limit is to add 50 percent of the working load limit of each tiedown used to secure the load; and if the total is greater than 50 percent of the load being carried, it is secured within the limit requirements. For example, assume that a trailer is being loaded with an 11,000-lb. telehandler, which will be held with four Grade 70, 3/8-in. chains. Since each chain is rated at 6,600 maximum pull, the aggregate working load limit is 6,600 lbs. divided by two. The total of the four chains added together is 13,200 lbs. That's more than enough to hold the 11,000-lb. telehandler.
Loading methods
Centering a load in the middle of the trailer is a basic tenet in proper loading, but it sometimes is overlooked when adding attachments or loading a large piece of equipment with limited view of the deck. Using a deck board as a guide to keep the load centered is an effective method of keeping the load centered. Overall, the weight of the load should be slightly forward so that 10 to 15 percent is on the front tongue. Fifth wheel trailers can handle as much as 25 percent of the load on the front.
http:
//auto.howstuffworks.com/auto-parts/towing/towing-capacity/information/overweight-load.htm
http://auto.howstuffworks.com/auto-parts/towing/towing-capacity/information/truck-tow-over-capacity.htm
   / What am I going to need to secure my Bobcat to my trailer? #4
Good advise given here. What I did was get 2 14' Grade 70 3/8" chain and 4 Lever Binders. I cut the chains into 2 each leaving me with 4 7' long pieces.
The ratchet style just take too long for me but nothing wrong with them. Grade 70 is transport category chain and will not get a second look from DOT. It is gold in color so very easy to identify and will not rust like the other types of chain.
Now to be totally honest I also have 4 27' 2" Ratchet Straps and 4 6' 2" wide Ratchet Straps that I use 90% of the time. I also got 4 21" axle straps. Much easier and its simply what I prefer but some say its not legal.
Here are some pictures of my straps.
Chris
   / What am I going to need to secure my Bobcat to my trailer? #5
You would probably need to check your state laws and see how many chains you need.
In my state i use two chains, one for the front and one for the back.
I take them and hook one end in the stake pocket, run through a place on the tractor and hook the other end to the other side stake pocket. Then use ratchet binders and tighten the chain up.
My tractor weighs 6100lbs. with the FEL, backhoe and a full tank of fuel.
You want to use ratchet binders, if you use the other type you will need to carry a cheater pipe to get the chain tight.
   / What am I going to need to secure my Bobcat to my trailer? #6
To be safe hauling your 5K load you should use 4 grade 70 3/8" chains and binders. Two in front, two in back.
Legally for loads under 10K you only are required to use one in front and one in back. When securing a load like this on a trailer I believe more is better and safer.
   / What am I going to need to secure my Bobcat to my trailer? #7
I use the 10000 lb ratcheting straps, I use 5, four corners and one on the center front. They are strong straps. Ultimately I'd like to go with chains and binders, but for my 5000 lb tractor I feel I'm good.
The straps were about 15 bucks a piece, much less than the chain and binder set up would be, someday I'll break down and get chains and binders.
Joel
   / What am I going to need to secure my Bobcat to my trailer? #9
All good advice here. New dot securement rules say that any wheeled or tracked equipment must be tied down at all 4 corners and any movable parts must be secured also. Such things as backhoe arms and crane booms are good examples of these. I spent about 10 years pulling flatbed and lowboy trailers with loads up to 16' wide and up to 120,000 lbs gross weights there is no such thing as too much securement imho.
   / What am I going to need to secure my Bobcat to my trailer? #10
Several mentions of DOT rules- question- are these state or federal rules? I've read the federal rules and there are requirements based on weight and length. The thing I noticed is they seem to address only commercial loads in interstate use. Now I tie my equipment down well, better than many I see on the road, but is a non-commercial user allowed to skate on these requirements? Seems so.
http://www.fmcsa.dot.gov/rules-regulations/truck/vehicle/cs-policy.htm
