What about bagging?
/ What about bagging? #1
smartguyz
Beaverton, Oregon
JD318, Power-Trac PT425 with scuffed-up green paint.
Hi,
There is a large area of my property where I consider a bagger to be essential for picking up leaves, not to mention during mowing of the lawn. I note that these tractors have no such attachment. How do you guys get around having to rake and bag? Do you need a separate machine?
Thanks!
-Rob
/ What about bagging? #2
My lawn area is pretty small, so I use a push mower. But, I don't even use a bagger for that. I take what I believe is the environmentally best route (and it just so happens to be the easiest route! /forums/images/graemlins/cool.gif) of letting the lawnmower mulch the clippings and return them to the ground. I also do the same thing with leaves, although I blow them into certain areas first.
Dave
/ What about bagging? #3
I set up a bagging system on mine - with a vacuum I purchased from cyclone rake - it works very well - especially after dethatching - the one problem I find though is length
- with my machine (1845) plus the deck out front and the vac out back it is really long and has got me into trouble in tight spots
it really depends on your property - plus I has to do some modifying because I didn't want the vac to trail the machine on wheels - I wanted it fully mounted - I still have not posted a photo yet - need to
I was re-thining the situation and thought about re-mounting the vacuum right on top of the deck with pins to remove it quickly - this way I could drop the whole unit deck, vac and all plus it would elliminate the elaborate hose system to the back and of course would really cut down on the length problem - (I have already destroyed a bush) but that would all come at the expense of reduced vision up front which might not be a bad trade off - so I'm still pondering
the bag would still fold down for storage when parking the deck for storage This is a big concern of min e since the deck basically stays on the machine only when I cut - I then move to the other attachments for variuos chores
2006 Heil DOT 407 Aluminum 9,000 Gallon Ethanol T/A Tanker Trailer (A64194)
2006 Heil DOT 407...
2025 TP25 25in Hydraulic Post Puller Skid Steer Attachment (A64553)
2025 TP25 25in...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
SDLANCH SDLC1220 High-End Carport (A64194)
SDLANCH SDLC1220...
2024 Polaris Sportsman 570 AWD ATV (A64557)
2024 Polaris...
2019 Chevrolet Malibu Sedan (A64557)
2019 Chevrolet...
