Wet vs. Dry
/ Wet vs. Dry #1
Big_Cajun
South Central Louisiana
MF 1130
Hello Gents:
Need some ideas and I know you've got plenty for me. I know the difference between wet sleeve engines and dry sleeve engines, but I want to know which is better as far as durability, life, rebuildability, etc.
Also, Wet clutch or dry clutch?
I was also reading up on inboard vs. outboard planetary gears. I also hear of something called a bull gear. Clarification, which is better, etc.?
Indirect vs. Direct fuel injection...which is more efficient, better, etc.
I'm just trying to learn as much as possible about the options available. I want to be an informed buyer.
Thanks for the input. I know that this may start some debates, but I want a feel for what your thoughts are.
Thanks again.
BC
/ Wet vs. Dry #2
BC,
I cant comment much on the other stuff, but I'll give my vote for direct injection. Its generally quieter,provides more performance, and lower emmisions. Most new diesels I am aware of are DI. Though, I'm not sure about tractors... Been doing some reading huh? /forums/images/graemlins/cool.gif
If I remember correctly,wet sleeves require anti-cavitation additives in the coolant to avoid cavitation from electrolysis....
Wet clutch, do tractors use them??? Thought this was just only available in motorcycles. Not sure of an advangage to either....Maybe the wet clutch would provide a little slippage and reduce heat?
In vs Outboard planetaries...... I've got a pretty good grasp on planetaries, but never heard of these types.
Good luck, I'll be watching this to learn more myself.. /forums/images/graemlins/grin.gif
/ Wet vs. Dry #3
Clutch and brakes -- the general industry consensus seems to be that wet is more resistant to heat buildup for both, especially under heavy loads at low speeds such as in ag equipment. You'll notice these are usually found on the bigger machinery, even in the CUT size ranges. Oil is better at removing heat from the metal than air is when there isn't a lot of fast moving air available like there is at highway speeds. On higher permformance cars there are special ducts to direct air at the brakes to help cool them. The cooling is necessary to keep the brake fluid from boiling and vaporizing, causing failure.
The thought of a device that works by friction running in an oil bath is a little counterintuitive to me, but they've been around a long time and work well, especially when subject to heavy loads, compared to dry units.
/ Wet vs. Dry #4
Wet sleeve motors are usually large displacement motors like in OTR trucks and avg 800k - 1m miles before inframe ovehaul. I would figure the large ag tractors would be the same.
/ Wet vs. Dry #5
A wet clutch is the best chose, but don't worry when it isn't available.
It depends of the model, the brand and the Hp of the engine.
There are also different dry clutches like a organic dry one
or a cerametallic dry clutch.
The cerametallic is the best but also the expensivest.
And the wet clutch is better as an cerametallic clutch but it is more expensive a it.
But it depends of the hp and if you have a good brand, i don't think you need to worry about the chose of the engineers.
/ Wet vs. Dry
I can't believe that these are all the comments on this topic...Are tractors built in such a way these days that these differences don't matter?
Please fill me in.
BC
/ Wet vs. Dry #7
</font><font color="blue" class="small">( I can't believe that these are all the comments on this topic...Are tractors built in such a way these days that these differences don't matter?
Please fill me in.
BC )</font>
I think you'll find dry clutches on older designs...my 790 Deere has a dry clutch.
I'm sure the wet clutch may be better (longer lasting) but dry clutches have been in tractors a long time.
As long as one is not abusive on a clutch (riding the clutch, for example), i reckon the dry clutch will last 1000 hours or more...or ten years, in my usage.
/ Wet vs. Dry #8
And a lot of that will depend on what the clutch does -- tranny, PTO, both, shuttling, etc. I'd expect more than 1000 hours. Both of my 8Ns were well past those hours, just based on age, and neither showed any sign of having been "broken" to fix the clutch. All the bolt heads had intact paint and so on.
/ Wet vs. Dry #9
I've a friend and now he is abusing his DRY clutch for more as 1800h, the tractor is 4 years old. But it depends a lot of the usage.
Like using the clutch in turns to slow down or using him at 2500 rpm...
/ Wet vs. Dry #10
</font><font color="blue" class="small">( As long as one is not abusive on a clutch (riding the clutch, for example...)</font>
I figure this would apply to wet clutches as well? They have a life span dependant on useage as well. Correct me if I'm wrong here...
2015 Ford Escape Titanium AWD SUV (A61574)
2015 Ford Escape...
2015 LeeBoy 8510C Asphalt Paver (A61572)
2015 LeeBoy 8510C...
2018 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 VOLVO VNL 6X4...
2016 Ford F650 Ext Cab Flatbed Truck (A62613)
2016 Ford F650 Ext...
2016 Sky Jack SJ8831RT 31ft 4x4 Rough Terrain Scissor Lift (A61572)
2016 Sky Jack...
3PT FENCE ROW SPRAYER (A63291)
3PT FENCE ROW...
