wet clutch
/ wet clutch #1
BHM
tandragee
MF
Can a wet clutch work the same as a dry clutch pressured with springs, does there need to be more springs on the wet clutch, if it is the same could a dry 13" clutch on a tractor be converted to a wet one.
/ wet clutch #2
Hi. Welcome. Don't think wet and dry clutches are the same animal. Usually wet clutches are multi-disc.
/ wet clutch
Hi, If a wet single brake disc works to stop with, could a single clutch disc work to start with.
/ wet clutch #4
The difference between the brake and clutch is the brake is stopping the momentum of the tractor. The clutch is applying force to drive the tractor beyond just its weight. A lot more force is on the clutch compared to the break. Converting a dry clutch to wet will not provide enough friction when wet to drive the tractor. This is the reason wet clutches are multi-disc to increase the surface area of contact.
/ wet clutch
Do you think there would be enough friction if a duel clutch could be converted, the two clutch plates to drive with, that it some one could make discs for me as it could not be got of the shelf.
/ wet clutch #6
Not sure what you are trying to accomplish. Dry clutches fail if they get wet or oil on them. They were not designed for wet applications.
Pipe Rack 5'9"Wx16'Lx6'6"H (A62679)
Pipe Rack...
1998 MAGNUM TRAILER (A65643)
1998 MAGNUM...
2020 KENWORTH T880 (A65643)
2020 KENWORTH T880...
2014 Lincoln MKS Sedan (A64557)
2014 Lincoln MKS...
Ingersoll Rand DD-24 Tandem Smooth Drum Roller (A64553)
Ingersoll Rand...
2011 Dodge Charger (Police), VIN # 2B3CL3CG7BH526995 (A65563)
2011 Dodge Charger...
