Western Plow pump
/ Western Plow pump #1
JB4310
Super Member
Central CT
J.D. 4310 E-hydro
I got this western 7.5' plow for free but it is missing the controls, I see the holes where the cables go into the housing but am not sure how it works, if I connect 12 volt to the pump terminals it runs non stop, is there an electric switch that gets activated when the control cables get moved. I had a newer version of this same plow but it was all electric, no cables.
Not sure what Im gonna do with it but even if I sell it I want it to work, might try and rig it to my tractor also.
Thanks, JB.
/ Western Plow pump #2
Go to westernplow.com then publications library and you can download the owners manual for your plow. It has all the info you need such as cable and wiring part numbers and diagrams.
/ Western Plow pump
Thanks, WOW! they do have a very informative, detailed owners manual with all kinds of tech stuff and even the theory of their systems, way beyond your run of the mill owners manuals.
It's kinda what I thought, there's a relay that turns on the pump at the same time the the cables actuate the valves.
So I need the joystick, cables and electric wires and relay.
Might just keep the blade and angle with the tractor's hydraulics. then sell the pump assembly, a new one cost $1,700.00, they're on eBay for $500.00 used.
/ Western Plow pump #4
I forgot to mention that's what I did when I bought a used western plow. I downloaded all the manuals, made my own truck frame and ordered the truck wiring harness I needed. After that it was just plug everything in and go. Ended up being 1/4 of the price of a new plow package.
/ Western Plow pump #5
You can also go to plowsite dot com or letstalksnow dot com and check out their respective classified sections. Someone on there probably has what you need - some of those guys have tons of plow stuff!
HTH
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
5 SHANK V-RIPPER, 3PT (A64277)
5 SHANK V-RIPPER...
2017 TROXELL  150 BBL ALUMINUM VACUUM TRAILER (A65643)
2017 TROXELL 150...
Morbark Eager Beaver 1215 (A63689)
Morbark Eager...
3 Point Boom Lift (A62613)
3 Point Boom Lift...
Allis Chalmers WD45 (A66285)
Allis Chalmers...
