OP
Francis_Mulligan
I believe the stabilizers are at their max. There is only one side of each that is threaded.
Well, I pulled up another picture of those stabilizers and they appear to be pinned at the tractor end and only the implement end extends...I think you spotted it. It is not the pins or bushings. The threaded sway bars are only extended at one end. Extend the other threaded end to an equal distance & it should fit.
Look at the photo you posted. It looks like only one end of the sway controls is threaded out. The threaded parts should be equal. You have more adjustment not being used.Like Francis - I went from Cat 1 tractor to a Cat 2 tractor. My problem was not the 3-point hook up.
My Cat 1 implements simply would not do the job I needed to do. Whether on the smaller or larger tractor. All my smaller jobs/projects were complete. With the larger tractor I am able to take on the larger projects.
I think Francis is going to get away easy. Slowly, but surely, over a five year period. Upgraded all my land engagement implements to heavier duty, just plain heavier - Cat 2 implements.
