Well Pump Electrical Problem
/ Well Pump Electrical Problem #21
Pulling too many amps causes the overload to trip, not the breaker. Again, this is easy if you just use an ohm meter to check for a short.
Sorry guys, I can't give any more details about the pump or the wiring. They live an hour from me and I only get over there every few weeks.....and.....despite being a decent weekend-warrior mechanic and carpenter I am an idiot when it comes to electricity.
@workinonit , I live below Charlotte. They live in the middle of nowhere between Winnsboro and Newberry.
I think right now, if we (me and them) decide to try anything ourselves other than checking pump verses breaker specs, it will be to run a continuous (unspliced) above ground wire to the well head and see what happens.
/ Well Pump Electrical Problem #24
400ft sounds like voltage drop from too small of wire, or water shorting the wire splice.
/ Well Pump Electrical Problem #25
I've got a well, along with my depth and distance from the pump, probably close to 400'. I did a simple resistance reading across the coils and from the coils to ground. The readings i got were very close to the resistance specifications for the 1 hp pump has across the starting and running coils. With that i was pretty sure my pump and wiring was ok. Not absolutely sure, but if my reading had been very different from the specifications, i'd know there was a problem with the pump or the wiring. Turned out i had a problem in the "pumptek" module.
OVERLAND VACUUM TANK (A60736)
OVERLAND VACUUM...
2011 Volvo S80 Sedan (A59231)
2011 Volvo S80...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2018 DRAGON 150...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2019 Bobcat T590 Compact Track Loader Skid Steer (A59228)
2019 Bobcat T590...
Chemical Containers Tank (A57148)
Chemical...
