Well pressure tank - What psi?
/ Well pressure tank - What psi? #1
California
Super Star Member
An hour north of San Francisco
Yanmar YM240 Yanmar YM186D
What pressure should I measure at the air valve on top of a well pressure tank? It's a little larger than a 55 gallon barrel.
Thanks in advance for any comments.
/ Well pressure tank - What psi? #3
But I have spoke too soon, boys in the office say they run between 50-60 psi
/ Well pressure tank - What psi? #5
Depends on what your pressure switch is set at.
For the pressure tank, your suppossed to shut water supply that goes to the pressure tank off. Then, turn on a faucet so the pressure tank empties.
Then, you check pressure at the schrader valve. There is a bladder in the pressure tank, that should be inflated to a psi detailed by the manufacturer. If the bladder pressure is too low or the bladder is leaking, your system will cycle excessively.
Pumps Tanks Motors And Wells - Frequently Asked Questions - PumpsAndTanks.com
Water tank air bladder pressure settings: How to Set or Adjust the Air Pressure in Bladder Type Water Storage & Pressure Tanks
/ Well pressure tank - What psi? #6
What RobertN said. It depends on the tank. Our is set for 20/40 PSI. You really have to know what you tank needs and the setting on the pressure switch.
Later,
Dan
/ Well pressure tank - What psi? #7
With the system empty of water, the pressure tank should be aired up to 2 PSI below the pump kick-in pressure. If your pump turns on at 30 PSI, the pressure tank air should be 28 PSI. You will need a fairly accurate air gauge to set the right pressure. A dial type or digital gauge will work better than the slipstick type.
Now this is all beginning to make sense, after I read through the material RobertN referenced for background. I need to install a water gauge that I trust matches my good dial-type air gauge.
This well hasn't needed anything for 15~20 years that I know of, and now it seems to cycle a little more when water is being drawn.
/ Well pressure tank - What psi? #9
If I recall right, I set the air on my bladder tanks at just a little less than the lower switch point on my 30-50 switch. I have two bladder tanks, around 150 gallon and the deep well pump has been in the ground over 20 years.
/ Well pressure tank - What psi? #10
I have always had a gauge next to the pressure tank. I have had to replace it though, as our yucky rusty water gummed it up...
/ Well pressure tank - What psi? #11
Right on the money... This is what it says in the instructions from the tank manufacturer.
What registers on the 'brass-tee' gauge doesn't matter (doesn't register) when the line pressure is at ZERO.
/ Well pressure tank - What psi? #12
If after adding air to the bladder you return to frequent cycling and low or no air pressure when the system is unpressurized, it's time for a new tank as the bladders fail and in most tanks, cannot be replaced.
/ Well pressure tank - What psi? #13
There are tanks that are sold as having replaceable bladders but I guarantee you don't want to go there.
/ Well pressure tank - What psi? #14
Our pressure tank was a fiberglass one installed by the well driller. The bladder got a leak within 4 years. The plumber installed a new metal tank. He did not like the fiberglass ones at all. Not sure why the tank material made a difference regarding the bladder lifetime...
The bladder in the fiberglass tank was replaceable. So said the manual. However I could only find one place selling the bladders and for the price of the bladder I might as well buy a new tank. Thus the call to the plumber. :eek:
Later,
Dan
/ Well pressure tank - What psi? #15
Have a 10 year old steel pressure tank that is set at 28 psi for the bladder. Have never known of a fiberglass tank before just now.
Ok, done.
The gauge at the pump showed cutin/stop at precisely 40/60 psi so I considered it accurate. I have a HF dial tire gauge that claims 'ANSI Class B' accuracy - good enough.
After draining the tank, the dial tire gauge showed it had only 25 psi. I filled it to 37.5 psi. This took a lot of air; I made three trips to the pump house with my 5 gallon portable tank. (filled to 115 psi each time).
Thanks everybody!
/ Well pressure tank - What psi? #17
Ok, done.
Thanks everybody!
Hmmm...loss of air in a bladder tank is not a "good thing". Try some soapy water around the schrade valve to see if a slow leak. Only other loss points are a broken bladder or leaking tank seam.
Harry K
/ Well pressure tank - What psi? #18
Just talked with my neighbor an hour ago, he had his 7 year old fiberglass pressure tank replaced a few days ago, it cost him $500 to have it replaced with a steel tank. The serviceman from the well drilling company said fiberglass tanks are junk and although they could replace the bladder on his, he would be better off just buying a new steel tank.
Oh, for what it is worth, I have only had to add air to our bladder one time in ten years, that was when I drained the tank to replace a leaking pipe in the primary inlet. It has maintained 28 psi just fine otherwise.
I didn't get a bubble when I tested the Schrader valve.
I know the pressure wasn't checked in the last 15 years that I have been responsible for it. I expect that checking pressure once in a while is all it needs.
