Well Im confused but happy. GC2410 blinker.
   / Well Im confused but happy. GC2410 blinker. #1
cdaigle430
Maine
MF GC2410
Was bored so I decided to trouble shoot why the blinkers blew the 15amp fuse every time. I checked and cleaned the switch and connecters and inspected wires. Removed the one relay closest to the engine and bam..blinkers work again. Put it back and bam, blows fuse.
So i left the relay our and out everything pack together. Works great now without the relay....but why?
From the repair manual.
   / Well Im confused but happy. GC2410 blinker. #3
On my 2310, the blinker seems to be tied in with the mickey mouse flashers (selected yellow light flashes, but the other stays on continuously); does that relay maybe something to do with that? Do your flashers still work normally?
   / Well Im confused but happy. GC2410 blinker. #4
bet w/o relay the blinker works but the solid amber on opposite side stays dark.
been long time since i had to work that relay but I have posted about wiring broken going into it I had to fix.
Yes the flashers work, left and right blinkers work, all lights work. So when I out the relay back in as soon as i put the left or right blinker on it blows the fuse. .Thats whats confusing.
   / Well Im confused but happy. GC2410 blinker. #6
At this point would you not suspect the relay is faulty?
Using the same numbers on the old relay, check the DigiKey website for a replacement/substitute.
Im trying to figure out how to test it for functionaliy without putting it back on the other side. I do suspect it is bad.
   / Well Im confused but happy. GC2410 blinker. #8
I doubt a "faulty relay" could cause a fuse to blow.
   / Well Im confused but happy. GC2410 blinker. #10
Think of a relay as an electrically controlled heavy duty switch, nothing more.
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
JOHN DEERE LA115 LAWN MOWER (A58374)
JOHN DEERE LA115...
2020 CASE SV280B SKID STEER (A52709)
2020 CASE SV280B...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
