Well Im confused but happy. GC2410 blinker.
   / Well Im confused but happy. GC2410 blinker. #1
cdaigle430
Maine
MF GC2410
Was bored so I decided to trouble shoot why the blinkers blew the 15amp fuse every time. I checked and cleaned the switch and connecters and inspected wires. Removed the one relay closest to the engine and bam..blinkers work again. Put it back and bam, blows fuse.
So i left the relay our and out everything pack together. Works great now without the relay....but why?
From the repair manual.
   / Well Im confused but happy. GC2410 blinker. #3
On my 2310, the blinker seems to be tied in with the mickey mouse flashers (selected yellow light flashes, but the other stays on continuously); does that relay maybe something to do with that? Do your flashers still work normally?
   / Well Im confused but happy. GC2410 blinker. #4
bet w/o relay the blinker works but the solid amber on opposite side stays dark.
been long time since i had to work that relay but I have posted about wiring broken going into it I had to fix.
Yes the flashers work, left and right blinkers work, all lights work. So when I out the relay back in as soon as i put the left or right blinker on it blows the fuse. .Thats whats confusing.
   / Well Im confused but happy. GC2410 blinker. #6
At this point would you not suspect the relay is faulty?
Using the same numbers on the old relay, check the DigiKey website for a replacement/substitute.
Im trying to figure out how to test it for functionaliy without putting it back on the other side. I do suspect it is bad.
   / Well Im confused but happy. GC2410 blinker. #8
I doubt a "faulty relay" could cause a fuse to blow.
   / Well Im confused but happy. GC2410 blinker. #10
Think of a relay as an electrically controlled heavy duty switch, nothing more.
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
2016 Nissan Sentra Sedan (A56859)
2016 Nissan Sentra...
55-Gallon Drum of 50/50 Antifreeze Star Fire Pure Fleet Red Heavy Duty (UNOPENED) (A59076)
55-Gallon Drum of...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
