Well....I tore some stuff up today
   / Well....I tore some stuff up today #1
MotorSeven
Elite Member
NE TENN (Hancock Co)
Kioti DK40SE Hydro
First I was trying to make a trail thru the woods to get to my deer stand so I could grub it out. I had cracked my sunshade lengthwise(3') earlier this year by driving under a low hanging limb in the pasture. While in the woods, I snagged it on a small dead tree & 1/3 of it shattered. I did make it back to the food plot area and was grubbing a little half acre area that had overgrown for 3 years. I was almost finished, went to back off of a pile of shrubs and jammed a 3" stick up under the left side engine shroud. The stick made it's way into the radiator fan and cleanly took relieved it of all the blades:( No damage to the radiator & I'm glad that the fan was plastic. A metal one would most likely have torn something else up.
I guess it could have benn worse. This is the second time I have managed to knock off the metal engine shroud. I think it could use a better attachment point, especially in the middle where things seenm to get between it and the bottom of the engne compartment. I may have to do a little modification to it.
Be carefull out there grubbing, particularly when backing up. It is just hard on our machines, but a necessary evil.
RD
   / Well....I tore some stuff up today #3
Ouch..wonder what your tractor nickname might be. ;)
   / Well....I tore some stuff up today #4
some days are just better spent __________________
   / Well....I tore some stuff up today #5
Clear to see when some have Rick tree proof their machines.
Always amazed at how strong some branches can be.
Joel
   / Well....I tore some stuff up today #6
A fellow who we rent heavy equipment from once told me that he will not rent machines for brush clearing,says he always ends up doing repairs if he does....Mike.
   / Well....I tore some stuff up today #7
Northcreek2624; I rented a dozer and excavator and had to SIGN an agreement that I would not use them for logging or wood clearing.
I was never impressed with the plastic sunshade or it's light weight mounting bracket. I kinda felt like in a roll over, I would be wearing it as a hat. So, I am going to take this "opportunity" to add a real roll cage w/front struts and put a metal roof up there. A belly pan would be nice & I am going to look into that while building the cage.
It's all "operator error", but some steel, mesh & welding can take some of the "error" out.
I'll post some pic's soon.
RD
   / Well....I tore some stuff up today #9
RD
Sounds like fun bring it by lets build it:D
One word to the wise...make sure you put some type of foam on the bottom of your new metal sunshade.... or you may think you motor has a bad knock to it.
The echoes you get from a metal sunshade will drive you crazy!
   / Well....I tore some stuff up today #10
If you need a fan we do stock them;)
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
