Well....I tore some stuff up today
   / Well....I tore some stuff up today #31
Highbeam, you mentioned slow leaks in the tires. Only my CK30hst left front will lose about a pound a week. It did this from brand new. Anyone figure out the culprit? I didn't know if adding slime in the tire would fix it or it's a bead or rim problem. It's just annoying and something I'd like to fix.
I had the same problem with the same wheel. I put a tube in for $ 8.00 and that was the end of the problem. I'm out in the bush clearing a road out to my back property and I may have pinched it sometime or another. No leaks now.
The Fox 1940
I would bet its a bead problem. With a FEL we put a lot of stress on the front tires when loaded and turning. Add a dip or hole or downhill stress and the beads pull away from the rim slightly. I was pushing on a 20'x8' steel truck bed that I made into a bridge with my ck30. A wrecker was pulling at the same time while we were getting it set across the creek. I had the wheel cranked over hard and, "WhooosH" , I pulled the tire tire completly off the rim. Needless to say that tire always leaked due to the grass & dirt that got jammed into the bead area.
RD
500BBL FRAC TANK (A58214)
500BBL FRAC TANK...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
