Well Head a good Ground?
   / Well Head a good Ground? #11
be carfull I would isolate this ground from your hosue ground. The differnce in potentiel will cause issues unless you can BOND the two grounds together.
BONDING the two grounds will require a larger conductor. Typical bond is number 6 copper between grounds.
You want the entire complex on the same ground potential.
   / Well Head a good Ground? #12
I know this question has the chance to bring allot of feedback, and controversy
Yes this one probably will bring out a lot of opinions and controversy.
But here's what I would tell you if you called me at my office, being a code professional. The NEC does not allow a separate grounding electrode (or system) to be used unless all of them can be bonded together. The purpose of the ground wire in your circuit is to provide a low impedance path back to the source through the ground wire back to the grounded (neutral) conductor where they are bonded together. If you use a separate ground, you will have created an extremely high impedance path.
I should add the outlet is going to be for the heater to keep it from freezing.And its location possible a radio in the summer.
A heater and radio may not even have a grounded cord supplying them. It was quite common at one point for no ground to be connected to a two wire well pump.
Now what would I do in your situation if it was me?
I would install a GFCI without connecting the ground to anything. It is perfectly safe and legal to do so. A GFCI does not need a ground to work. It measures the unbalanced current between the hot and neutral. If they are not the same, then there must be a fault to "ground" and it kicks out.
BTW, the NEC now recognizes a metal well casing as being a grounding electrode that must be bonded back to any other grounding electrodes that are present. They are mainly used to stabilize voltage and dissipate transeint voltage such as lightning.
Inspector, Thanks,for explaining it. the way I understand is that the GCFI with just the white and black is still preferred even if there is no bare ground wire.This is what I shall do.
I guess I wasn't thinking of the heater having a ground.. I was more thinking that it would be advantageous to somehow use a GCFI I quote you
Good to know I didn't realize this before.
Most likely noting would happen with the present set up, but I'd rather error on the safest path.
I will use the GCFI without any ground wires to it.
Again thanks all for the info....
   / Well Head a good Ground? #14
That is interesting and helpful info regarding the gfi not needing a ground to function, only problem is all the new gfi's have some smart feature where it wont let you energize the outlet if wired wrong, don't know if that means it would sense the missing component ground?
JB.
   / Well Head a good Ground? #15
Back in the nineties, I had a house with a very very wet basement that I was trying to sell. The inspector wanted a GFCI for the sump pump but as mentioned, the GFCI would trip.
If I recall correctly, I read an article on hospital rated GFCI's being better for wet areas. My local supplier thought I was nuts to spend twenty five bucks for one but it actually worked.
Someone more knowledgable please feel free to chime in.
Yes now my curiosity has peaked on just how and where the GCFIs are to be used.I have a sump now on a GCFI I assumed it was the right thing to do. they wires are all head high, I don't anticipate any troubles but is it how the code would have it now adays?
(Is a GCFI required for a sump?)
   / Well Head a good Ground? #17
Not sure, but probably not, since it would be undesirable to have it trip unnecessarily. Ideally you would have your sump pump on a dedicated 20 amp circuit, not because there's any great demand but to protect the circuit from being tripped off by something else on it.
When I had my kitchen redone, to meet code there's about 8 circuits in there now, one separate for every appliance plus counter outlets. only the counter outlets are gfi protected. The microwave, refrig, dishwasher and disposal are all on separate 20 amp circuits but not gfi.
I have GFIs everywhere they're supposed to be (I think) baths, porches, garage, outdoors, in the basement (half finished) every outlet is gfi protected except washing machine, not sure if that's code cause I did it myself but I think that's what I must of been told.
I have a sump pump in the basement of my little shop that is not on a gfi. not sure about code cause I did that one myself also.
JB.
   / Well Head a good Ground? #18
JB.
That's correct, they do. But I do believe it senses reversed polarity not the ground. I could be wrong though.
Yes the 2008 edition of the NEC now requires all receptacles in the basement to be GFCI protected. Including sump pumps.
   / Well Head a good Ground? #19
Back around 1982, I was working with a company putting up wind mills. We inherited the service on one when the original installer went out of business. The hill top site was subject to some serious lightning.
We got a call to come and check out what was left of the inverter, etc. after a strike. Seems the tower was grounded to the well casing which ended in bedrock while the well hole went deeper. During a drought, the water level dropped below the well casing.
I do not recall if the well was bonded to the main or not but man those big capacitors were smoked!
2013 INTERNATIONAL REEFER TRUCK (A54607)
2013 INTERNATIONAL...
New JMR Skidloader Stump Bucket (A50775)
New JMR Skidloader...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
2007 JLG SKYPOWER 800AJ TELESCOPIC MANLIFT (A52705)
2007 JLG SKYPOWER...
NEW HOLLAND C345 SKID STEER (A52705)
NEW HOLLAND C345...
