well drilling / puunding
/ well drilling / puunding #41
We pounded our well in 1993, went 200' and have great water, but not a lot of volume, (5gpm). Our next door neighbor went the rotary route, went 400'+ and got crap for water - high sulfur and iron and no better yield. The pounder took almost 2 weeks, the rotary was in and out in the same day. The old timers in the neighborhood recommend pounding.
/ well drilling / puunding #42
5 GPM is usually considered much more than adequate for household use.
I know people who live on 1/3 GPM wells, and get along fine. They do need significant storage capacity.
/ well drilling / puunding #43
I have about 3 GPM pounded well 125 feet installed in 1979. One pump motor.(knock on wood)
Plenty of water and recovery. Just don't water the lawn etc all at once.I do about 8-9 loads of laundry a day(kids).
Not a problem.
Al
I wen't back this weekend the operator had pounded 220ft so far he said it was his best in a week he is due back Monday. My wife is staying up there this week and will keep me posted
tom
The latest update they pulled off Tuesday after Labor Day and never told me.
I couldn’t get up there to check on them because of my work schedule.
450 ft and 1/2 gallon a min water was up to 300 ft level approximately 200 gallons in well.
I asked them 3 or 4 times if they could go to 600 ft and haven’t got a straight answer why they left the owner says there are lots of houses that are on 1/2 gallon a minuet and with the 200 gallon storage in well I would be fine.
I got the bill with no driller report (required by state) I called and asked when he was going to finish up the job? He said he was done! I faxed contract to my lawyer he said to pay the bill and ask for the drillers report in writing.
Lawyer suggestion with the amount I was out take him to small claims court to cover the cost of having some one finish the job properly.
I got 2 estimates so far around $3000.00
I have to call the county sheriff to file a claim.
Then I will call better business bureau
tom
/ well drilling / puunding #46
Tom,
That's a bummer it turned out that way. The driller must be an ***hole. Hope you win the suit...serves him right.
What do the other drillers say about getting more water?
/ well drilling / puunding #47
Just like grandpa! I put my own well in 30 years ago. I pounded a 1" 1/4" point into the basement floor and installed a 1/3 horse pump. The water table is down 18 feet. I measured by dropping a nut tied to a string into the top of the pipe. I then pounded the point to 6 feet past the top of the water table, used a pitcher pump till the water became clear and installed the pump. Good, clean, soft water is something we have plenty of in Michigan. Total cost $300.00
/ well drilling / puunding #48
On the subject of 'witching'. While can do it (and do), I don't trust it. I ran into an oddity the other day. Needed to dig out my septic tank. I was fairly sure on the location but wasn't positive about edges. Tried the rods. They picked up the drain pipe in just fine but wouldn't show anything on the tank itself. Traced the pipe right up to it and then nothing.
Harry K
/ well drilling / puunding #49
tommu56 said:
450 ft and 1/2 gallon a min water was up to 300 ft level approximately 200 gallons in well. tom
1/2 gpm x 60x 24 =1460 gallons + 200 = 1640 gallons per day. Are you really that short of water ? 5gpm = 7200 gallons -nobody uses that in a residence.
What depth was discussed before the job started? I've never seen a pounder go much more than 450'. Not any pounders left in NH that I know of but there used to be quite a few. Now all are all rotary because they charge by the foot & can do more feet per day. Also make major bucks from refracing the wells, which was seldom done with pounded wells.
Here's another well driller that says you have plenty.
Tasker's Well Company, Inc.
search for other "Tasker's " articles -they've been drilling in NH for a long time. MikeD74T
/ well drilling / puunding #50
There are still pounders around in NH. I had mine pounded 4 years ago by a guy from Henniker, after talking to another pounder out of Concord. I also know of another in Alton who pounded me one about 10 years ago. Although I haven't seen him for some time, I would be very surprised if he weren't still "pounding away."
/ well drilling / puunding #51
Do you still have their names? MikeD74T
/ well drilling / puunding #52
I think there is one out of Canterbury. I think the name is Kelso.
John Wunderlich from Johns Atersian passed away earlier this year. He had a pounder on an old Reo chassis.
/ well drilling / puunding #53
The guy in Henniker is Bill Gould. The one is Alton is Loring Carr. I can't think of the one in Concord. I would think if you contacted the Water Well Board, they might be able to provide a list of operators with cable machines.
Licensing Well Drillers, Well Design Code
Water Well Board
29 Hazen Dr.
Concord, NH 03301
271-3139
For what its worth, I've always believed pounding was the best method. NH DES has the following posted on their website when discussing the two methods:
"Some experts contend that the percussion process better fractures the rock in the immediate vicinity of the hole, and the bailing of water and pulverized particles keeps the rock fractures from becoming clogged with the drilling mud and rock cuttings. These two actions are believed to result in higher yields of those wells drilled by the percussion process. In recent years, drill bits for the rotary drilling machines have been redesigned to include a percussion action to better fracture the rock. Rotary drilling is normally less expensive and much less time consuming than percussion drilling. DES does not recommend any one method of construction over another."
More info can be found at: Bedrock (Artesian, Drilled) Well Design
2012 International (A59230)
2012 International...
2021 JCB 35Z-1 Mini Excavator (A61572)
2021 JCB 35Z-1...
2013 FORD F250 (A60460)
2013 FORD F250...
1779 (A64280)
1779 (A64280)
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
UNUSED RANCH HAND BRUSH GUARD (A64280)
UNUSED RANCH HAND...
