Welding Trailer
/ Welding Trailer #1
Hosskix
Midland, Texas
JD 790
OK guys, here's my first project since buying my tractor.
I decided that I needed to build a shed to keep my tractor in, therefore I needed a welder; after I found a good used welder I needed a way to haul it and the cutting torch around, along with the misc tools that welding always seems to require; so a small trailer was the perfect fit.
I had intended to use an old motorcycle trailer that I had but after looking it over I decided that it would probably be easier to start from scratch!
So, I talked to my boss and was able to work a deal to buy an old air compressor trailer that our business no longer needed.
my.php
I started out by stripping off all the stuff that I didn't need.
my.php
Then I dry fitted everything on it to get my measurements and the placing right.
I later bought another tool box instead of the plastic one I was using in this photo.
my.php
/ Welding Trailer
I skipped a lot of steps here (I forgot to take my camera to the shop the second weekend of work!), but you can get the general feeling of what went on; I welded all the supports and braces, made the combo small work table/spare tire cover and built a vice holder (For the vice that should be coming in anyday now!).
Here it is painted with the new tires and wheels on it.
my.php
Here I'm mounting everything on it for good, still need to take it to the house to get my cutting torch and bottles.
my.php
/ Welding Trailer #3
WOW Looks great. I am always impressed to see 'old' metal being used again.Great Job..
Al
/ Welding Trailer
Here's the final result:
I still need to mount the vice and find some quick-connects for my torch (so that I can lock it up in the tool box) but it's serviceable, just waiting on the weather to clear up a bit so I can go to work!
I probably have about $2500 dollars in it, including the $1600 for the used Hobart welder.
I'll bet I get my money's worth out of it!
/ Welding Trailer #5
:D Looking good.:D
Put some lockable covers over the cables. They make dandy booster cables!:D
/ Welding Trailer #6
That's a great looking remade welding trailer, you made very efficent use of such a small area.
/ Welding Trailer #7
Hosskix
That trailer looks great. Well thought out. I have a few welding jobs at my place. When are you available?:D
/ Welding Trailer
Thanks a lot for the reply's guys!
wushaw- Yep, took a lot of figgering to get everything I wanted on it without having to extend the trailer, I just liked the fact that it's only 10' long from tip to tail, I can get it just about anywhere and and park it in my tractor shed that I'm fixin' to build.
Egon - I'm thinking about building a vertical lock box for the cables and hoses to hang up in, that'll keep them protected from theft and UV's.
I was just in a hurry to get it done and useable!
radman1 - I wouldn't even know where to start figgering out how to charge for a trip to Nebraska! That'd be some pretty 'spensive welding! ;)
/ Welding Trailer #9
You might want to consider adding a piece of sheet metal on the front uprights. The first time you pull that when it's been raining, you'll have road spray all over everything. I'd also suggest getting covers for the welder and tanks for the same reason. The sheet metal will deflect about 80% from your vehicle, but road spray from oncoming vehicles (like 18 wheelers) gets all over (and in) everything it can.
/ Welding Trailer #11
looks good... but what is the shelfy thing in the front for? covering the spair tire? (no not the vise mount the other thing with a V at the front)
/ Welding Trailer
It's a combo work bench and spare tire cover.
I'm 6-2 and getting the "middle age spread", bending over and cutting or grinding something at trailer level kills my back after awhile.:p
It's hinged so that you can lift the work table up to get the spare out rather than try to wrestle it out from underneath.
I'm thinking about putting a hasp on it to lock it in place but I may not bother, I live in the country and it'll rarely be seen by anyone.
The V thing at the front is a piece of angle iron turned on it's side and welded to the table, works great on a work bench for laying stuff in to keep it from rolling off and you can lay a piece of pipe in it while cutting or grinding when you don't want to mess with the vice. (So you don't have to loosen the vice to rotate it or something.)
/ Welding Trailer
Hey swines, I'm in West Texas, what is this "rain" stuff you speak of?
Sounds terrible, I'd hate to have that problem!:D
Just kiddin, good ideas, I've already looked into getting a cover for the welder and tanks, but in all likelyhood it'll be parked under a shed most of the time and if it's raining, I ain't welding!
Had some of that as a kid, trying to hold a piece of pipe in place while someone trys to to weld it does funny things to the muscles in your arm!
I would like to have some as dust covers though.
/ Welding Trailer #14
Hosskix,
Very nice rig! It looks like it has been well thought out. I had a similar rig with a Miller Bobcat. The biggest problem I had was that a couple of my buddies would come and get the welder and it would disapear for a week or so. I took it of the trailer and put it on a heavy duty cart, but they would just bring their trailers and load it up! These guys are like brothers and I couldn't tell them no, but it bothered the **** out of me. I wound up selling the Miller to buy a new Browning O/U shotgun. Ironically, my buddy bought a bigger Miller on a trailer, and has left his MIG welder and plasma cutter in my garage for the past couple of years. Good luck with your new toy, and keep posting pictures of your projects.
Shovel
/ Welding Trailer #15
Any particular reason you chose "white" paint? Seems like that's going to be real hard to keep clean. Nice job though. Free is always nice.
/ Welding Trailer #16
If you want a heavy duty denim fabric cover for your welder, there is a poster over on the Miller and Hobart boards that custom makes them. He also sells on Ebay but I don't know his username. I bought 3 of his covers for my MM251 mig, Spectrum 375 plasma cutter, and TA185 tig machines. His username on the welding boards is Fun4Now. He makes quality stuff for a reasonable price.
The pics show the Spectrum and TA185. He had to send me another one for the Spectrum since Miller changed front panel designs in early 2006.
/ Welding Trailer #17
Miller makes a cover for that machine, it looks just like my Bobcat.
/ Welding Trailer
All my other trailers are white, my pickups are white and the white paint was free....not much thinking went into it!
Seriously, I know that up in North Texas, in the red and black clay areas, white does get dirty quick.
But out here, where it's mostly caliche roads and alkali dust, white is the cleanest looking color there is.
My trucks have to be filthy before they look as dirty as a darker vehicle with a coat of dust on it.
Anyhow, thanks for all of the replys and compliments guys!
/ Welding Trailer #19
I've always had a preference for white vehicles & equipment because they DO get dirty quicker. When my stuff gets dirty, I clean it. The more often I clean it, the more often I look it over closely.
I recently sold a 28 year old truck. It was still in nearly perfect working order and no rust because I couldn't stand to see rust or dirt or greasy crud on that nice white paint.
My stuff lasts a long time. :)
/ Welding Trailer #20
Hosskix: You are a majician. That is a terrific turnaround for the old trailer. Can you get another one and build me a pig cooker on it?
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
2001 International 3800 School Bus (A64194)
2001 International...
Grey Fox Portable Creep Feeder (A66408)
Grey Fox Portable...
