welding tips with propane
/ welding tips with propane #1
deereman75
canada
Deere 2120, Warner & Swasey 6000# offroad forklift, Case W9B loader, various non-running decorations
Question for you guys. I am picking up a purox torch tomorrow (used) that comes with 6 welding tips.
My question is, will these standard acetylene welding tips work with propane for brazing? Is there anything dangerous that could go wrong? Should I just give it a shot?
I am thinking of getting a #200 propane rosebud for it. (purox has a different number system)
Sure, it would drain my oxygen tank in 20 minutes, but it would sure be nice for heavy bending!
/ welding tips with propane #2
All my welding and heating tips work on propane. Welding steel needs the extra heat value of the Acetylene plus the control of the carbon content of the puddle which propane does not have. Cutting tips are special for propane as the heating part is different due to the difference in heat value of the gasses.
Ron
/ welding tips with propane #3
I have always used acetylene until I recently decided to at least have the propane option. Just ordered propane cutting tips and a #8 rosebud nearly 3 weeks ago. The rosebud was back ordered until 7 Sept but they are finally sending the cutting tips after I complained about their email stating shipping in 4-7 days and two weeks later not yet shipped. Looking forward to how propane works.
/ welding tips with propane #4
It is difficult to maintain a propane flame on an acetylene tip, especially a welding tip. The flame tends to get blown out very easily. It's very hard to adjust and maintain the flame.
Propane tips are recessed for more stability.
My standard rosebud works okay on propane but welding and cutting tips are a problem.
Note also, that propane degrades standard acetylene hoses over time. It's best to replace the hoses with an "all fuel" hose.
/ welding tips with propane #5
I don't think you will have much luck trying to use the acetylene tips for anything except acetylene. Interesting to hear how it works out..
Well, I will give it a shot. If it doesn't work, I might see about getting a 390cf acetylene tank....
I can see my self using a lot more gas soon. I am considering setting up a business account with air liquide, and leasing their biggest tanks....
I think that with the biggest acetylene tank, and mainly using propane for cutting and heating, the cost wouldn't be too bad.
/ welding tips with propane #7
Cutting with propane is somewhat acceptable for me, it does take a little longer to preheat. I don't like propane for heat shrinking at all!:thumbdown:
Here are some pictures of a propane rosebud, and an acetylene rosebud.
/ welding tips with propane #8
You cant weld with propane, the flame is not inert and will encapsulate air in the bead.
/ welding tips with propane #9
Acetylene is the ONLY fuel gas that, when combined with Oxygen in a neutral flame, has the by-product of CO2 which acts as a shield gas... Steve
/ welding tips with propane #10
I thought it was CO( carbon monoxide) not CO2 (carbon dioxide).
/ welding tips with propane #11
From this site
http://www.weldingandgasestoday.org/index.php/2011/07/alternative-fuels/
"Common Misconceptions
One big misconception is that alternative fuels cannot be used for welding steel because the flame is not hot enough. Considering that carbon steel alloys melt between 2,500o F and 2,800o F, this is quite inaccurate. The real reason is that alternative fuels don’t create any shielding gas. Conversely, a proper mixture of oxygen and acetylene with a neutral flame produces CO2, which in turn shields the molten weld puddle from atmospheric contamination. Realistically speaking, this is not much of a drawback, as most industries have substituted other processes for oxyfuel welding."
There's a lot more, follow the link if you like... Steve
/ welding tips with propane #12
i suppose it may depend on your brazing rod, but i have brazed with propane, MAP, and Acetylene, knowing what i usaully have on hand it was probably Silvalloy 6 or 15.
/ welding tips with propane #13
Brazing / soldering uses a lower temperature melting point filler rod than the material being joined and is not the same as welding. Welding is using a filler rod that mostly matches the chemical composition of the welded material and when done properly, makes a homogenous weld that closely matches the composition of the parent metal when completed.
/ welding tips with propane #14
I have still never seen any Brazing Tips for Alternate Fuels. To run Propylene or Mapp, Propane Etc. in an Acetylene tip may not be the safest program.
2017 Mercury SeaPro Outboard Boat Motor (A61574)
2017 Mercury...
Rogator RG1300C (A63688)
Rogator RG1300C...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
2015 Ford Fusion AWD Sedan (A61574)
2015 Ford Fusion...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
CASE TR340B SKID STEER (A64279)
CASE TR340B SKID...
