Welding sproket
/ Welding sproket #1
caseyvand
Dunvegan, Ontario, Canada
Hi....I need to weld a 4 inch sproket (for 40 chain) on a 1 inch shaft. All I have is a stick welder. How much of a warp problem can I expect on the sproket? I would guess the shaft will be ok. Any suggestions on what kind of welding rod to use? This shaft is off a 47inch JD snow blower.
Thanks.....Casey
/ Welding sproket #2
Why don't you want to key it and use set screws repair will be much easier.
You don't need to weld the whole circumference of the gear 3 1/2" welds on each side should hold it if metal is all new 7018 or 6011 if it is dirty
stitch one side go 180 stitch the other side keep flipping back and forth side to side it shouldn't move.
/ Welding sproket
Hi......I was thinking of welding because that's the way it was done before. But can you tell me if the metal outlets or machine shops sell 1 inch shafting with keyways already cut?
Thanks.....Casey
/ Welding sproket #4
Sure here is were we get them from at work pre made
shaft 3" to 72" you don't need test report
McMaster-Carr
24" x 1" American Iron and Steel Institute (AISI) -0.0005" to -0.0025" 0.012" per foot 1497K101 $41.35
sprocket
Part Number: 6280K844 $25.10 Each
$25.10 Each
Type
Drive
For Chain Number
ANSI 40
System of Measurement
Inch
Pitch
1/2"
Bore
Finished
Finished-Bore Type
Includes ANSI Keyway and 2 Set Screws
Bore Size
1"
Shape
Single Strand With Hub
Number of Teeth
23
ANSI Keyway Size (Width x Depth)
1/4" x 1/8"
Outside Diameter
3.94"
Width
1"
Hub Diameter
3"
Material
Steel
It cant get any easier spending your money :laughing:
I order from them for my self a lot of the times because they usually have stock call today have it tomorrow afternoon.
tom
WhisperWatt 125KW Gen Set DB-1381J2 (A64911)
WhisperWatt 125KW...
TWO PALLETS OF HYD TANK, V8 ENGINE BLOCK/PARTS (A67714)
TWO PALLETS OF HYD...
2018 GRASSHOPPER 900D MOWER (A66091)
2018 GRASSHOPPER...
Rhinox Mini Excavator Root Rake (A64912)
Rhinox Mini...
No compression. Unknown operating condition. (A64553)
No compression...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
