Welding round tube...Help please
/ Welding round tube...Help please #21
I bought the Harbor Freight jig before I bought the jig I listed above. It fell apart on the first hole/cut. The bushing come completely out and it was not worth fixing. I returned it.
Cary:cool:
/ Welding round tube...Help please #22
Sandlot said:
I have been thinking about this little tool. Anyone have one?
Harbor Freight Tools - Quality Tools at the Lowest Prices
I have one, and for the money, it is hard to beat, but as with most hf tools, it has its limitations. the bushing material can wear quickly, and I have heard some people mention that their tube vise is not centered with the madrel for the hole saw. I have used mine quite a bit building bumpers and cages for jeeps, and have no complaints for the price. for more $$$, better units are available. Like the bandsaw blades, I highly recommend a good quality bi-metal holesaw. use a low spindle speed, and some cutting oil. too much or not enough down pressure on the saw while cutting will shorten the life of the cutter.
/ Welding round tube...Help please #23
cityfarma said:
Thanks, I will give it a try. Just looks like it is a lot of work to get a good fit.
Cityfarma
It always is. It usually takes a lot longer to prepare for the weld than to do it. :D
/ Welding round tube...Help please #24
You might get some insight what i and others discussed in this thread:
http://www.tractorbynet.com/forums/build-yourself/105561-building-dirt-buggy-1.html
look at this photo: http://www.tractorbynet.com/forums/...6579788-building-dirt-buggy-08082007-001-.jpg
I dont really have time to proceed with the fun projects: First need the road sweep to put back to use, the grader blade and the straw bale chopper. Oh, and i need new brakes on my tractor, as well as some oil leaks that need attention.
(i'm excusing myself before people start asking when i post more progress :D )
/ Welding round tube...Help please #27
weldingisfun said:
Great info. Thanks.
:D
What if instead of a "T" joint, I want the notched tube at a 15* angle with my first 1.75" tube???? You must start with your base angle, which was 28* for 1.75"(remember above), and subtract 15* from one cut, and add 15* to the other cut to form a perfect notch. So now I must make a 13* cut and an 43* cut with the point centered on the tube. Perfect coped joint, with no grinding.
remember most tube (if new) has a line/seam drawn down the side that can be used as a "centerline" when makeing the notches. makes things that much simpler to aim for the "center".
/ Welding round tube...Help please #28
schmism said:
:D
Good point.
Used Landpride GR1525 Stump Grinder
Used Landpride...
2022 CATERPILLAR 313GC EXCAVATOR (A65053)
2022 CATERPILLAR...
2014 CHEVROLET 2500 SERVICE TRUCK (A64278)
2014 CHEVROLET...
Ground Protection Mats (A64194)
Ground Protection...
UNUSED 2023 JCB S4550E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
