Welding Question
/ Welding Question #21
I'll second the ease of the 6013 rod. On a DC setting with my Hobart welder, I can teach my 10 year old to run a good bead in 1/2 an hour of training. Fortunately, for all but the strongest welds, the 6013 rods are a pretty good all around rod.
/ Welding Question #22
Jim I bought the 80 amp unit cause I was feeling cheap, but I was still able to weld bucket hooks. Even though I'm 6 years out of practice with a stick I got enough penetration that when the stump was too big the back wheels came up /forums/images/graemlins/shocked.gif
Only problem with a 6 lb welder is that the 10 lbs of rod weigh down the bag /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Seriously, I probably should have sprung for the 90 amp unit, Holzster, it would be easier to weld tractor thickness materials with a few more amps.
I'll have to try some 6013, I was using 7014 because I couldn't get some 6011 to strike. Maybe when I build that weight box????
/ Welding Question #23
Those little welders are so cute it might be worth dumping the tombstone in a graveyard for a much lighter unit. You could backpack that thing anywhere as long as you had power to run it.
/ Welding Question #24
Started out learning on a 120v Miller mig XP130. Great little welder, very versatile and will handle light up to 1/4in steel. Grew out of that and now have Miller 175, 220v mig rig. Love it. Neighbor has a stick welder, swears by it. Theres a welder for everyone. Practice practice practice. Get a good auto dim helmet.
/ Welding Question #25
I don't have a problem with 6011s. That's about all I use. 'course I fire it up with a Miller 251NT Trailblazer set at about 105 amps. The one thing a Trailblazer has that very few other welder/generators have is two generators. One 3 phase for the welding and a separate AC generator for the "plug in" stuff. Used it today as a matter of fact...BobG in VA
/ Welding Question #26
Today my 251 Trailblazer got in six hours, most of them at a hundred and eighty amps. We cut out the original factory weld holding the wear bar on the bucket of a John Deere 655C late model which was fractured and rewelded it. I used about ten pounds of 7018.
I like the Trailblazer because it just flat out welds better than comparable machines. When someone asks me what the difference is between my Trailblazer and a Bobcat I tell them the Trailblazer comes with two magnets. One for the stinger and one for the ground. All the weldor has to do is change rods because the machine welds by itself. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
It's almost a waste to run A/C rod like 6011 when you have such a fine DC machine like the Trailblazer. You need to try Lincoln 5P+ on positive. If you do that you'll never go back to 6011 even though it costs a third less.
/ Welding Question #27
</font><font color="blue" class="small">( With a Mig you change over to a sheilded/flux wire. Essentialy becomes a wire feed welder.
)</font>
Yeah.. but the time involved in doing that can be substantial. With a stick welder you can use any rod, whenever you want to depending on application. If wind comes up.. no problem .. keep working.
On mig.. if wind comes up.. it would be quite a buzzkill to stop.. spend 5-10-20 minutes to convert to flux wire.. etc.. and then get just a tad better looking weld that stick anyway.
And yes.. I doubt you have the electrode versatility with mig as you do stick.. or if it is available.. I sure wouldn't want to have to keep 3-5 spools of different wire laying around that I might use once in a blue moon.. where as electrodes are cheaper and easier to store in smaller quantity.
Soundguy
/ Welding Question #28
Thanks Harv for the hint on the 7018s. I'll give them a try! BobG in VA
/ Welding Question #29
WroughtnHarv - so do you think my 80 amp machine would run the 5P? I'm relearning stick after 2 decades of MIG and, although the welds are holding, I'm worried about penetration with an 80 amp machine.
Lou
/ Welding Question #30
You could probably run 3/32 with an 80A machine, but I'd hesitate running anything larger with it.
5P+ is basically a 6010 rod. Deep penetrating, tolerant with dirty material.
Hays LT1 Tender (A61307)
Hays LT1 Tender...
2025 SB05 Hydraulic Breaker Mini Excavator Attachment (A59228)
2025 SB05...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
Freightliner Columbia (A61307)
Freightliner...
