Welding question ...
/ Welding question ... #21
Well I guess like most said its cheap insurance to dissconect. so why risk it.
But as was also mentioned most devices are still connected to ground through the truck. So in witchcraft situations At least your battery will be safe :cool:
/ Welding question ... #22
Yeah,its a good question for sure,once you think about it a little.
But I'm sure there is somebody out there who can tell us so us dummys can understand why,what,etc.
I been around welding for many years,can't tell you why?
I know computors have come into play here,but don't forget the battery charger thing I mentioned.And most things like the rear light I just put on,is grounded to tractor.
Maybe it kinda caught in the seams here,mechanic not a welder,welder not a mecanic,computor guy,don't know what a welder is,etc.
/ Welding question ... #23
Having quite a bit of electronics experience and lots of experience troubleshooting electrical interference gremlins, I think the reason the portable welders might not cause a problem when welding on the vehicle it's mounted to is because the portable welder shares a primary ground plane with the vehicle. I'm not just talking about the ground clamp either. Welders are generally going to have a transformer in them. Feeding power through a transformer can do weird things if measures aren't taken to equalize the ground planes on both sides. If you connect your ground clamp to a vehicle that has an internal power supply, then electrically speaking, your welder's ground may actually be at a lower potential than the vehicle's ground. If that is the case, then power can feed back through the vehicle into the welder's ground, particularly if you're using an A/C welder. Reversing the current flow will do all sorts of bad stuff to electronics.
Now, the portable welders, on the other hand, even if they're driven by a separate engine, they are usually bolted to the bed of the truck. That creates an electrical ground connection. As long as both sides of the transformer share the same ground then your generator/welder's ground will always be at the same potential as the vehicle's ground.
Now, none of that takes EMI into account. Electromagnetic interference can also wreak havoc with a vehicle's electrical system. I drive a Pontiac Aztek, and absolutely love it, but I have to be very careful when disconnecting the battery that I don't make a spark. Azteks are very sensitive to EMI and voltage fluctuations and their body control module and gauge cluster in particular are know to die suddenly after a battery connection has sparked. I belong to an Aztek owners group and it's really surprising to hear how many of them have had electrical problems after a simple battery change.
/ Welding question ... #24
Curious- how do you disconnect the battery making sure you don't get a spark?
/ Welding question ... #25
Make sure all electrical accesories are turned off then disconnect your ground, if your still gettin a spark there could be an open or a short still creating a circuit.
As far as most portable welders the case is isolated and isnt grounded to the ground terminal of the welder. IE you cant strike and arc off the case without throwing your ground clamp on it.
I was talking with my welding supply guy today and his explanation was " Vehicle alternators have a voltage regulator for a reason, if your alternator spikes then you fry electronics. Welders are giant alternators (Kind of) and if your creating an electrical circuit through a vehicle with an electrical device that is higher then what the electronics are designed for so things start frying."
I also think of it like, when lightning hits your house, it frys stuff inside. Its a larger scale picture then whats happening but similar principle i believe.
/ Welding question ... #26
We're still trying to figure that out. What I generally do is try to move as quickly as I can to get the terminal against the post. I've been considering putting a main switch on my main battery feed to try to permanently solve this problem.
/ Welding question ... #27
Years ago when I was a youth,:rolleyes: I had a job loading large and small sail boat on to trailers for shipment back east. Occasionally the boat's cradle need to be welded to the flat bed trailer with the truck still attacked. The driver always had me ground the trailer and truck to the earth with a bar of metal. I never knew why, but always did it. Of course this was before all the new computer controls.
Cary:cool:
/ Welding question ... #28
All loads or accessories off helps the most, but would one of those RV type battery disconects be good enough to skip the sparks?
Like this about $10 at P.A.
/ Welding question ... #29
That would probably be sufficient. If you want to be 100% certain, a contactor with magnetic blowouts would probably be best. For those that don't know what I'm talking about, there are switches out there for high voltage or high current uses that have a pair of relatively high-power permanent magnets with like poles positioned on either side of the switch contact so that their magnetic field lines intersect the gap between the contacts. Since electrons are deflected by magnetic fields they can't arc between the switch contacts without a lot of power driving them.
/ Welding question ... #30
Just for the sake of it, Whats the price on a contactor with magnetic blowouts these days?
2001 Subaru Outback AWD SUV (A59231)
2001 Subaru...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58214)
2012 TEX MEX...
(INOP) 2004 INTERNATIONAL 4300 SBA TRUCK (A59823)
(INOP) 2004...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
