Welding Pot Metal
/ Welding Pot Metal #42
when it turns cooler I'll post pics of that potmetal piece I fixed. just no time with both jobs going and the farm right now.
soundguy
/ Welding Pot Metal #43
Not sure if it will help, but I've used a product called HTS 2000 in the repair of Automotive Aluminum A/C hoses with very good results. The product also says it can be used to repair Pot Metal, Galvanized, and White Metal. It takes a little practicing to get used to it.
TD
/ Welding Pot Metal #44
A good way to eliminate a dozen or more names for the same product is that the Welco 52 is half round with a flat side. Many many others are exactly the same. When I was a Harris Welco Salesman, I would walk up to the gypsies booths where they were selling the rods via microphone and they would just look away. They knew they were selling the stuff for a 400% margin. Thats ok, It works for the most part. There are a few others that work too.
/ Welding Pot Metal #45
if they could sell it at a 400% margin.. good for them. sounds like they had way better marketing skills than the people selling the same stuff ( welco ). :)
capitalism baby! free market rules!
soundguy
/ Welding Pot Metal #46
You got me curious so I went out and looked at the HTS 2000 rods and they are round but varying rod sizes range from .087 to .075. I've had pretty good luck with this product. I practiced on aluminum soda cans that I punched a hole in then repaired. I've never used the Welco 52. I'll have to try them.
TD
/ Welding Pot Metal #47
I have a few questions about the welco 52 stuff
1. what is best heat source to use for it? O/A? propane?
2. how much does it cost from say my LWS?
3. do you need any flux for it?
/ Welding Pot Metal #48
The rods I've seen and used work well with a hand held MAPP gas torch. The guy I got mine from (barker at the fair with 400% markup) insisted that you never put the rod in the flame. You heat the base metal and then touch the rod to it. If the rod doesn't melt, heat some more.
The funny thing is that I've never been able to braze with it as well as I did at the guy's booth at the fair. I don't know what the difference is.
/ Welding Pot Metal #49
propane is fine.. the hotter it gets.. the harder it is to work with from my experience, as the rod melts back from the heat being applied to the parent metal.
I'd also like to note that it has to be clean clean clean.. I use a stainless steel brush that ONLY gets used for that application when doing the pot metal.. I also use the rod to kind of scratch along and scratcht he surface.. IMHO.. it probably is removing the oxide layer.. etc.
ps.. the one I use often is alumalloy.. I have used 2 others.. one from the chinese store.. one from northern tools..
soundguy
/ Welding Pot Metal #50
Alumalloy is one I remember. The 52 was always called a "Rub On" rod because you try to keep it out of the flame. If you do get it in the flame it melts right off. Also the 52 has a flux for applications that don't want to take the filler. I guess in the end, I would use this kind of stuff as a last resort. I have a bunch of it in a rod guard but never really use it.
/ Welding Pot Metal #51
I looked on the harris website, and I couldnt find a word about welco 52 (or anything 52), I wonder if they stopped making it. The only aluminum brazing things they list are Cor-Al, Al-Braze 1070, and ALCoR.
/ Welding Pot Metal #52
/ Welding Pot Metal #53
Lincoln Electric bought Harris and discontinued a ton of household named products. I suppose 52 was one of them. Cor-Al is a Nasty flux cored rod ok for fixing small holes but the flux used to eat the shelf the rod sat on. You could never get it flushed good enough to prevent it from eating itself. Al-braze 1070 is solder that will join any metal to any metal at 1070 degrees. people freaked out seeing stainless or copper soldered to aluminum at shows. Marginal product but cool at shows. AlCor is cool for joining all but the 60 series aluminum. It has a flux core and flows like water and is very strong. I like the stuff on the right material. It turns liquidous at 780 degrees so you can use a Turbo Torch or lessor quality propane type torch.If anyone wants to try a stick or 2 of 52 I would be ok to send it out. I have a bunch and doubt I will every use it. I actually have a bunch of AlCor too but would have to have a few bucks for a tub.
/ Welding Pot Metal #54
http://www.e-harris.ru/harris/files/catalogue/776.pdf
http://www.stoodyind.com/Catalogs/FISC/current/05catpg373.pdf
found the msds at harris, and the product at stoody.
a lil aluminum, a lil copper, and alotta zinc....
soundguy
There it is... See above..You "can" repair Pot Metal.. Funny how the 120 is listed as a welco product. I remeber going to school at MG and they had a 120 that was for aluminum and pot metal with the same #10 flux as welco 1070..my point is so many companies make products for each other it's difficult to know what comes from where. Harris used to draw Silver Solder for Lucas Millhoft and Wolverine and they would all compete for the same business. That was the nice thing about being a Harris Salesman. You could offer better pricing. Same with Hyperthem offering Miller a 20 year old Plasma torch to use on their Plasma Cutters ( some say made by Hypertherm ) So that they could have Auto Link on the Plasmas. It's all just business and most have no idea what goes on behind the scenes.
CAT D9G Rollers (6) (A68134)
CAT D9G Rollers...
THERM DYNAMICS TD 375 FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
THERM DYNAMICS TD...
225/70R19.5 Tires - Set of 2 (A68134)
225/70R19.5 Tires...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2009 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
2006 KENWORTH W900 (INOPERABLE) (A67714)
2006 KENWORTH W900...
