welding on atv
   / welding on atv #1
mbown
Indianola Iowa
260 c ford new holland
I need to do some welding on my Artic Cat 375 hitch. My concern is what do I need to do before welding Or is it of any concern? to protect the alternator?
   / welding on atv #2
Disconnect the ATV battery and keep your welding ground close to the hitch you are welding.
   / welding on atv
Thanks for the quick reply,will proceed from here.
   / welding on atv #4
I have also either removed or thrown a wet blanket/towel over anything that can catch fire or melt from welding sparks. Like plastic seats or fuel tanks - especially fuel tanks.
   / welding on atv #5
Good plan.. Also I always do a double ground when ever electronics are concerned. Use the welder ground close to the joint and I run another to earth or another source. You wont have any probs.
   / welding on atv #6
Can't go wrong by disconnecting the cdi, battery, keeping ground clamp as close to the weld as possible and a FULL gas tank.
An extinguisher-ABC type nearby and a quick means of egress; keep your path to the exit clear.
Sent from my iPhone 5s 64Gb using TractorByNet
2015 Kia Sedona Van (A51694)
2015 Kia Sedona...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
Hyster H225E (A47384)
TEST BID LOT (A50775)
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
