Welding oil field pipe and sucker rods
   / Welding oil field pipe and sucker rods #1
Deere5420
SW MO
J.D. 5420
I have a Hobart 210 mig welder with a generator. I am building a perimeter fence and using oil field pipe and sucker rods on the corners. If I use flux core wire (.35), do you think this will work without it breaking continuously? Don't really want to break down and buy a gas powered stick welder. Thanks.
   / Welding oil field pipe and sucker rods #2
As long as generator has capacity to handle the initial surge loads when you first strike arc there should be no problems.... HOBART recommends a generator with about 50% more watt ratings the what welder actually draws..... This keeps generator from bogging down every time you strike arc....
Hydraulic Reservoir (A49251)
Hydraulic...
2005 Isuzu FTR Truck, VIN # 4GTJ7F1365F700278 (A48836)
2005 Isuzu FTR...
2012 IC Corporation PB105 School Bus (A48081)
2012 IC...
2013 Fiat 500c Lounge Hatchback (A48082)
2013 Fiat 500c...
96in Large Capacity Bucket (A49251)
96in Large...
John Deere 5410 Tractor (A48837)
John Deere 5410...
