welding machine adjuster
/ welding machine adjuster
Just some examples, how much force is needed?
This motor would work with those power supplies: 2RPM, 75 inch pounds, 0.8 Amps at 12VDC - 2 RPM 12 VDC GEARMOTOR
21 RPM 12VDC, 4.5amps at stall: 21 RPM 12 VDC RA GEARMOTOR. Would need this power supply: 5 amps at 12VDC with 100-240VAC input - Amazon.com: R-Tech UL Listed Regulated Power Adapter, 12VDC, 5 Amp for Surveillance Security Camera CCTV: Camera & Photo
Aaron Z
I guess I'd have to somehow adapt a torque wrench to it.. right now its just got a crank on top which winds the center field up and down inside the transformer? im not even sure how many cranks it would take from min setting to max... but I would never go down that low anyhow as I said I stay pretty much between 90-and max 155..i'll have to do some research
LOT LOCATIONS (A59908)
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2023 FONTAINE INFINITY FLATBED TRAILER (A59823)
2023 FONTAINE...
900 GAL SEWAGE VACUUM BED (A60736)
900 GAL SEWAGE...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
