sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,841
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
pmsmechanic, I am from Kimberley, not to far from you, thank you for the imput.
I have been trying to cross reference the part numbers to see if they were on any other machines but I was having no luck. I will try again now. I had a closer look tonight and the cracks propagated from the mounting bolts to an access port, then to up and over the top and down to another access port on the left side. Then horizontal back to the front. It seems to me that on the right side around the mounting bolts there probably was a stress crack there from me carrying too big of logs in the past with the loader or from the classic plowing into a frozen nugget in the winter. Then yesterday working the loader it finally gave way. It's hard to say but there seemed to be dirt in the crack near the mounting bolts and inspection port and clean up and over the top to the other side indicating old and new cracks.
Does anyone know of any tractor wreckers? I will start by searching this forum.
'll have a closer look at it when I split the tractor to see if it can be welded. It does not look shattered and It does hold a magnet so it must be cast steel so a little easier to weld.
Cheers
Kelly
Sorry to hear of the cracked housings - here is a used tractor parts outfit (Draper Tractor Parts) Tractor, Crawler, Combine Parts & Salvaged Equipment -never know?? they do have a free 24 hour locating service, hopefully a used piece is available Good luck
