welding cast housing?
/ welding cast housing? #21
pmsmechanic, I am from Kimberley, not to far from you, thank you for the imput.
I have been trying to cross reference the part numbers to see if they were on any other machines but I was having no luck. I will try again now. I had a closer look tonight and the cracks propagated from the mounting bolts to an access port, then to up and over the top and down to another access port on the left side. Then horizontal back to the front. It seems to me that on the right side around the mounting bolts there probably was a stress crack there from me carrying too big of logs in the past with the loader or from the classic plowing into a frozen nugget in the winter. Then yesterday working the loader it finally gave way. It's hard to say but there seemed to be dirt in the crack near the mounting bolts and inspection port and clean up and over the top to the other side indicating old and new cracks.
Does anyone know of any tractor wreckers? I will start by searching this forum.
'll have a closer look at it when I split the tractor to see if it can be welded. It does not look shattered and It does hold a magnet so it must be cast steel so a little easier to weld.
Cheers
Kelly
Sorry to hear of the cracked housings - here is a used tractor parts outfit (Draper Tractor Parts) Tractor, Crawler, Combine Parts & Salvaged Equipment -never know?? they do have a free 24 hour locating service, hopefully a used piece is available Good luck
/ welding cast housing? #22
Here are some of my favourite ones. Medicine Hat tractor wreckers 1-877-527-7278. Medicine Hat probably won't have it but they do get parts out of the States. Gratton Coulee 1-780-754-2303. Westlock Tractor Parts 1-800-563-0112. Sexsmith Used Farm Parts Ltd 1-780-568-4100/ 1-800-340-1192.
I do buy parts out of the States and have a freight depot in Sweet Grass, Montana which is just south of where I live. If you want to use it pm me.
/ welding cast housing? #23
On John Deere's parts diagrams they have a "Where used" search. You look up the part number and then type it onto the search blank. It'll tell you on which equipment the part number is used. It's pretty handy.
/ welding cast housing? #24
The pics you posted would indicate an almost impossible task of welding it back together but the description you give sure sounds as if its even worse than the pics show. I would start looking for a replacement part and forget about repairing. This is one of those that will keep breaking no matter how good the welder who tackles it is. Just too much ground to cover for the type and strength the welds will need to be to hold it together not to mention as others have pointed out the prep work for the welding will be extremely difficult to get right.
Wengers of Myerstown is just over the mountain from me and should be able to help you out with the parts needed.
Good luck with the repair!
/ welding cast housing? #25
[/QUOTE]
I have had good luck with this guy. Not high tech but a lot of stuff.
Dave M7040
Byers Brent Tractor Supply
RR 1, Crysler, ON K0A 1R0
1-800-510-5505
/ welding cast housing? #27
DJ54 wrote this in "Re:826 international hydraulic filter"
For used parts, whatever they may be, you can copy part numbers, and go to TractorHouse http://www.tractorhouse.com/Default.aspx#PartsSearchTag and paste the part number in the appropriate block to search many salvage yards in their system.
I din't know this and thought it might help you out too.
/ welding cast housing? #28
Just fill the cracks up with dirt and mud... Then trade it in at the John Deere dealer... I would not try to fix that tractor... John Deere will make the trade, then when you are long gone they will pressure wash the tractor to get it ready to sale and see the crack... They will then fix it or just scrap the tractor... You will be money ahead and get a bigger tractor for your needs... It time that some one stuck it to John Deere...
/ welding cast housing? #29
The big one around here(WY/MT) is Utah Track & Welding in Salt Lake City 552-6931. Area code is 800 or 801.
/ welding cast housing? #30
Problem with this is they may do a very small, get by repair, or not even see it at all, then sale it to a buyer "As Is." Seen it happen on pickup trucks and engines.
/ welding cast housing? #32
If you end up welding these parts, one trick that I have used in the past is to use a needle scaller to peen the welds after each pass or deposit. And I mean a heavy peen. This acts as mechanical stress relieving process. It will minimize distortion. Later.
/ welding cast housing? #33
We have a very good recycler here in AB, They ship all over North America . Gratton Coulee Agri Parts Ltd ph: 780 754 2303 They are located in Irma Alberta. Lots of Stock
/ welding cast housing? #34
I have had good luck with nickel rod, but as it has been stated above , u must be meticoulous in your procedure.
/ welding cast housing? #35
I have had 3 of these units they are notorious for this issue I have split all 3 tractors and have had the housings welded costing about 1000-1900 depenfding on how bad the welds were. All worked after and held up as good as the original factory garbage. You abosolutely have to find a welder with the knowledge and capabilities to weld cast iron, this process is a heating then welding heating then welding laborious painstaking process so that there are no bad sections of the weld. It can be done it is cheaper than a replacement housing and John Deere are crooks for putting out such a substandard product I know of at lease 50 of these tabs myself that have had the issue. They should at least pat for housing but they refuse as they slip under the guise that the loader bolts loosen on this machine and as part of preventative maintenance one should keep them tight just like greasing the machine before use. Unfortunately no-one tele you that when yo buy one nor anywhere else other than trial n error or finding out the hard way after the machine splits, you will probably have to check the input splint o the hydrostatic drive pump as when these crack it makes an uneven parallel in the tractor and th only part holding things together is the pump where it connect into the motor. this usually bends or breaks either way if you fix without addressing that issue you will have more problems later.
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
2010 Deere 318D (A60462)
2010 Deere 318D...
2015 Hyundai Genesis 3.8 Coupe (A61574)
2015 Hyundai...
Massey Ferguson 383 Tractor (A64047)
Massey Ferguson...
211297 (A62131)
211297 (A62131)
