Welding cart idea
/ Welding cart idea #1
Uncle Levi
Maxbass, north Dakota
John Deere 2020
Mine is far from perfect, but it may give some of you some ideas to work from. 002.jpg003.jpg004.jpg005.jpg
/ Welding cart idea
NO comments....Hmmmmmmm..................This must be a REALLY bad idea.
/ Welding cart idea #3
I hope you aren't welding anywhere near that area(guess that's why the need for a welding cart). I don't think I have ever seen a workshop that crammed full of stuff.:laughing:
/ Welding cart idea #4
I weld in a barn, and have been planning to build an offroad cart. I have a platform where my shop is, so I can roll my current welding cart around fine, but if I want to move away from that, it's all gravel, and a pain. I am going to move up to a Thermal Arc 252i here in the near future, so I will build the cart to suit that. I plan on 8" aired tires, two in the back and skids on the front, and handles that will pull out and be used to push like a wheelbarrow, and push in/use to coil the gun and ground cables on otherwise. I want to be able to push this thing over gravel and semi-rough ground, because that's where some of my welding occurs. I like your idea of a wagon that you can pull, but I do want mine to be short, so it doesn't take up as much room in my shop.
/ Welding cart idea
I have a Lot of stuff stored in here during the long North Dakota winter. It gets cleaned out in the spring and I weld in my blacksmith shop.
/ Welding cart idea #6
Havent been to North Dakota but have been thru Montana and Wyoming during Jan and it is a real bear up in that part of the country. I think you guys get lower temps there than Northern Alberta Canada.
KMC 4R ROLLING CULTIVATOR (A63291)
KMC 4R ROLLING...
2019 Volvo VNR64T T/A Sleeper Cab Truck Tractor (A61573)
2019 Volvo VNR64T...
2020 Godfrey Marine Hurricane Boat w T/A Boat Trailer . (A61574)
2020 Godfrey...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
