Welding cart idea
/ Welding cart idea #1
Uncle Levi
Maxbass, north Dakota
John Deere 2020
Mine is far from perfect, but it may give some of you some ideas to work from. 002.jpg003.jpg004.jpg005.jpg
/ Welding cart idea
NO comments....Hmmmmmmm..................This must be a REALLY bad idea.
/ Welding cart idea #3
I hope you aren't welding anywhere near that area(guess that's why the need for a welding cart). I don't think I have ever seen a workshop that crammed full of stuff.:laughing:
/ Welding cart idea #4
I weld in a barn, and have been planning to build an offroad cart. I have a platform where my shop is, so I can roll my current welding cart around fine, but if I want to move away from that, it's all gravel, and a pain. I am going to move up to a Thermal Arc 252i here in the near future, so I will build the cart to suit that. I plan on 8" aired tires, two in the back and skids on the front, and handles that will pull out and be used to push like a wheelbarrow, and push in/use to coil the gun and ground cables on otherwise. I want to be able to push this thing over gravel and semi-rough ground, because that's where some of my welding occurs. I like your idea of a wagon that you can pull, but I do want mine to be short, so it doesn't take up as much room in my shop.
/ Welding cart idea
I have a Lot of stuff stored in here during the long North Dakota winter. It gets cleaned out in the spring and I weld in my blacksmith shop.
/ Welding cart idea #6
Havent been to North Dakota but have been thru Montana and Wyoming during Jan and it is a real bear up in that part of the country. I think you guys get lower temps there than Northern Alberta Canada.
2010 International 4300V TYMCO 500x Regenerative Air Sweeper Truck (A66736)
2010 International...
Hot Tub (A64912)
Hot Tub (A64912)
2012 CATERPILLAR CP56 PADFOOT ROLLER (A65056)
2012 CATERPILLAR...
2015 Bobcat S570 (A64911)
2015 Bobcat S570...
CAT 416F Front Loader Bucket (A68134)
CAT 416F Front...
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
