Welding advice
/ Welding advice #11
I was wondering is 7014 might be a better choice as there is no embrittlement issue but again I am not a welder hence my reaching out. At this point I am a Google welder :)
I did some fillet weld break tests. 7014 broke with 10-blows from a 4-pound hammer. 7018 that never seen the inside of a rod oven broke with 18-blows from a 4-pound hammer. 7018 right out of the rod oven broke with 23-blows from a 4-pound hammer.
/ Welding advice #12
I find 7014 is more of a fast weld rod, still strong, DC 7018 is more of a penetrating rod which in turns makes it a stronger, but if one only has an AC only machine, 7014 is a good choice, if a gap and crap is present, 6011 works good first, then 7014, or DC 7018.
/ Welding advice
Point taken. I will discuss with my neighbour, hope to get this fixed this weekend as I am behind on my projects :)
Am amassing equipment to do my own welding but there is nothing like doing it as they say. I have a Canox 225 Sparkler that I picked up at auction, helmet and some rods so far. Looking to get lessons from the neighbour, he's a great asset! Going to take the loader off and check the alignment of the mounts as I suspect the previous owner rolled the tractor. Thanks again for your advice, much appreciated. Great forum
/ Welding advice #14
That loader repair is an excellent reason for carbon arc gouging, and or plasma. I've done a lot of gouging and a little plasma and both will shave off that old weld right down to bare steel without going through the base metal, cutting torch will to but one has to be good and accurate, one wrong move with a cutting torch.........
/ Welding advice #15
skipjack I'm just a hobby welder myself:eek::eek:. I think you will want the repaired weld to look something like this weld.
/ Welding advice #16
Weld it right and skip the strengthening add-ons if you ever want to sell it. My two cents. Jim
While I TOTALLY agree with this I must admit that I have been guilty of "add-ons".
Terry
/ Welding advice
Sorry for the late update. All welded up20170804_160646.jpgNot super pretty but holding up quite nicely
Hidratrak 8' Rolling Cultivator (A53317)
Hidratrak 8'...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
2014 Ford Escape SUV (A59231)
2014 Ford Escape...
2021 FORD F-150 STX CREW CAB TRUCK (A59823)
2021 FORD F-150...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
