Welding a hydraulic hose
   / Welding a hydraulic hose #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
Ok here we are. Broken hose fitting. Done for the day?
No
30 minutes later I’m digging again.
Only problem is I have to remember to replace it.
I welded a short bead, then sprayed water on it to prevent heating the rubber hose. Repeating all the way around.
That's why it's an ugly weld.🤣🤣
   / Welding a hydraulic hose #2
Yup, been there! Not broken, but had to make up some adaptor fittings that didn't exist.
Looks like that hose was getting ready for replacment anyways!
Hose still in good shape, I broke the fitting with “operator error”.
Got back to work but it drips dangit.
   / Welding a hydraulic hose #4
As crusty as that fitting looks i figured the hose wasn't far behind lol.
Hopefully it holds until you can get a new hose made up.
Steel will hold. Worst thing about this is "it works" and other repairs rise higher on the list. Luckily "it drips" which will keep it on the list to make it right. I just went back to work, and have not checked if its a weld pinhole or leaking at the connection. nIt could be the fitting, or its mate was damaged by the impact.
TMGT I've welded fittings together too (to make compact adapters).
   / Welding a hydraulic hose #6
it is good to have a welder
2021 Ford F-250 4x4 Ext. Cab RKI Service Truck (A52377)
2021 Ford F-250...
Electric Concrete Mixer (A51573)
Electric Concrete...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 84"...
Under Body Toolbox (A51573)
Under Body Toolbox...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
