Welder / Wiring for Small Garage
   / Welder / Wiring for Small Garage #71
Think so worked telecommunications for 38 years and everything from 26 gauge to 750,000 CM... And I can read the spec provided by welder manufacturer...
hold on, you are aware that #10 wire is larger and carries more current than #14 right?
   / Welder / Wiring for Small Garage #72
Think so worked telecommunications for 38 years and everything for 30 gauge to 750,000 CM... And I can read the spec provided by welder manufacturer...
i guess i'm confused about your point?
are you objecting that i gave advice that exceeded the min requirements for this specific equipment?
for the record i acknowledge that the min requirements for this equipment are as low as #14 wire for specific conditions (that i have no way of knowing for sure), i still would recommend #10 wire and a 30 amp CB.
   / Welder / Wiring for Small Garage #73
I am not objecting to anything.... Just referencing minimum requirement the welder manual states..... Which also makes reference to NEC sections...
   / Welder / Wiring for Small Garage #75
I would run awg 6. You won't regret it when you buy the next toy and find out you need a little more power. I ran #2 to my shop but it is 130' from the house and I have added numerous circuits since I originally wired it.
   / Welder / Wiring for Small Garage #76
Having more capacity sounds good, but the original post said he already had 50 amp service with #6 to the building and is just adding a circuit for the welder. If you are installing a 30 amp breaker for the welder circuit, anything larger than #10 is just wasted money and added difficulty in handling the larger wire.
   / Welder / Wiring for Small Garage #77
I agree with what you said but laughing at myself because i just talked myself into installing 3/0 for my service, it was a PITA, had to borrow a set of ratcheting cutters to cut it and forget about bending it neatly
   / Welder / Wiring for Small Garage #78
Just brainstorming ... if a future EV would be charged near the far end of this cable run, then more wire capacity now might be a good idea.
   / Welder / Wiring for Small Garage #79
After the wheel fell off of by canoe, you asked how many birds will fit in a dog house, I say well it doesn't matter because a fish doesn't have feathers.
Just trying to add a little humor!
Boy that was a long one.
Haha 😀
Well life happens wind storms that make us have to replace the roof and vacation.
Also, my around to it needs to get back in gear. 🤪
That said I’m sticking with what I outlined.
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58214)
2012 TEX MEX...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
Vicon Seed Spreader Parts (A57149)
Vicon Seed...
