Welder: Pulled the Pin
/ Welder: Pulled the Pin #1
RonL
Banned
Worcester, Massachusetts
Caterpillar 416C IT, Caterpillar D3G, previously owned a Ford 1910
After much research, I pulled the pin and bought a welder. Went with a Miller Big Blue 500. 500 amp at 100%, 12 KW 120/240 single phase, 20 KW three phase, 47 HP Perkins turbo diesel, and a 25 gallon fuel tank. The 20 KW three phase was important to me.
Waiting for it to come in now.
RonL
/ Welder: Pulled the Pin #2
Wow, that sounds like a serious welder!
Ron
Ron
The welder part is probably more welder than I'll ever need, but at least I won't have to worry about duty cycle. The three phase power was critical in that I wanted to run a machine that was close to the limits of the welder. And, it will run the biggest plasma cutter. The machine will also be my emergency generator.
I suspect the machine will long outlive me.
RonL
Well, it finally came in. What a monster. Started it up and that Perkins purrs like a kitten. Impressive machine. I'm charging the battery for the digital camera. I'll post pictures tomorrow.
RonL
/ Welder: Pulled the Pin #5
We just had one of those come through our shop for some warranty work. Sure is a beast. That Perkins is actually a Shibaura engine which is a very good, reliable engine. I guess Perkins and Shibaura are now the same company and CAT owns them all. Anyway, I wish I had one of those...I'm blue with envy.
/ Welder: Pulled the Pin #6
</font><font color="blue" class="small">( Well, it finally came in. What a monster. Started it up and that Perkins purrs like a kitten. Impressive machine. I'm charging the battery for the digital camera. I'll post pictures tomorrow.
RonL )</font>
ROTFLMAO......Ok Tim... using a 12kw generator to charge 2000ma batteries /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
That would be a little excessive.
I also bought a Hypertherm 1650 plasma cutter. I wired that up to Big Blue today and cut up some steel. I bought a one inch by three inch by twenty foot piece of ar400 steel to use as teeth on a dozer root rake. Once I got used to it the plasma cutter did a good job of cutting the steel. Only problem I had was that my little Hitachi portable compressor could not keep up. Naturally, my big compressor is up at my property in New Hampshire. What Lincoln does that I wish Miller did is put a full output three phase plug on the front panel. Miller requires you to hard wire to the three phase. I'm going to run a wire out to a plug once I get the machine set up.
Didn't get a chance to take pictures today.
RonL
2017 FORD F-150 FOOD TRANSPORT TRUCK (A65643)
2017 FORD F-150...
New/Unused Quick Attach Open Back Mounting Plate (A65583)
New/Unused Quick...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
Cattle Feeder (A65640)
