welded trailer balls
/ welded trailer balls #1
jack707
up North wisconsin
farm trac 555
I had to weld this up because I was not going to spend 30.00! After all I had one just had to weld it to the reciver because when I cut it the shank it was not long enough to go thru the hole so how did I do? I had some 8018 left so I use them.
/ welded trailer balls #3
Looks good, but I'd still keep it off the road.
I have a few inserts that are homemade, and others that have had repairs. They get used behind the tractor pulling the wood hauling trailers, shuttling the logsplitter around, etc.
Not that I dont have confidence in my welds, as I believe they would hold whatever I wanted to tow......but its the liability thing. Too much risk to take over a $30 ball/insert combo.
/ welded trailer balls #4
I wouldn't use that over the road. 30.00 is not much to pay when a life may depend on it. .02
I just put this together to tow my log splitter in to town. Then I won't use it anymore.
/ welded trailer balls #6
For off road use :thumbsup:
/ welded trailer balls #10
I'd be OK with any use...
You can buy a welded ball assembly from Harbor Freight, and it's welded in China with sub-standard components, using sub-standard equipment... Your welds look solid, and from a materials standpoint, there really isn't any issue with what you've done.
I take that back. Generally speaking, you need to grind off the chrome plating before you weld, I believe. But you welded the top and bottom, so it's probably 2x stronger than the crappy HF 3-way ball mount, and I HIGHLY doubt they grind the chrome off the balls before they weld them.
Nice looking welds, btw. :)
Thanks a lot 1st.Deuce! I know it's stronger I use 8018 that's 80 pounds per inch of weld!.
/ welded trailer balls #13
No doubt it is better than a HF China one. The difference is the liability IF something happens
/ welded trailer balls #15
Hitches are designed to resist shear loads with a shank through a thick plate. As long as there is a shank through the plate, welds just provide a clamping force.
The question is, is there a shank on the bottom of the ball that extends through the thick plate?
Yup there is just long enough not to go thru the bottom hole.
/ welded trailer balls #17
Your welding is replacing the clamping force of a nut and it appears to be solidly welded on the bottom. Just to be on the safe side, I would grind a slight groove around the top of the existing bead to remove the chrome on the ball. Then put 2 passes around the ball, one on the bottom with half overlap of the existing bead then the second on top of the first with half overlap taking care to tie the weld in good on the ball. Don't step the rod in and out of the puddle like it appears that you did on the top bead, keep the rod in the puddle and drag it slowly around the ball. LH rods don't like to be stepped due to slag entrapment and porosity forming.
After that, I would not be afraid to run it anywhere.
As far as liability goes, if a HF Chinese welded ball did break off, I rather doubt that you could claim any liability from the manufacturer so you had better have some good insurance in any case.
New/Unused Wolverine 66in Quick Attach Rock Bucket (A65583)
New/Unused...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
1987 GMC C7000 Fire Truck, VIN # 1GDM7D1G3HV526472 (A65563)
1987 GMC C7000...
Willmar Wrangler 4500 Loader (A66285)
Willmar Wrangler...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
2019 ISUZU NPR 16FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 ISUZU NPR...
