Welded a Cat 650 Dozer stack (MIG)
/ Welded a Cat 650 Dozer stack (MIG) #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
Lots of members (I think) are trying to decide whether to get a MIG or a stick-welder. Or would like to see examples of tasks that can be accomplished with the MIG they have. Here's an example (,,,,,,way on the thin end ! ) of a repair that can be done with a MIG.
Today a freind asked if I could fix the exhaust stack on a dozer. I said yes. How difficult could it be? Well I had NO idea the metal on this beast would be so thin. It must be 22ga (1/32 inch). And rusty too, so even thinner than 22ga in many areas. It was not an easy weld. Wherever it was rusty was constantly filling holes, and where I had full thickness (22ga) it wasn't really easy.
Heres some pics.
441709d1443071064-welded-rusty-22ga-exhaust-mig-cat_exh_09-jpg
The rusted out part is a cone reducer (from 5" to 4"). This stuff was underneath a wrap of coffee cans and pipe clamps. When I said I'd fix it I didn't know what was under there.
441710d1443071064-welded-rusty-22ga-exhaust-mig-cat_exh_10-jpg
441711d1443071064-welded-rusty-22ga-exhaust-mig-cat_exh_11-jpg
Decided to proceed. At this point, seeing how rusty and run-out this stack is, I'm not concerned how it looks. Just want to get the stack on, and exhaust away from the operator (at least for awhile). Also hoping he'll let me use the dozer! If the friend wants to bring the correct materials such as an actual reducer, I'll weld that in for him.
441712d1443071064-welded-rusty-22ga-exhaust-mig-cat_exh_12-jpg
Luckily this exh stack is more like a "guide" attached to the "hood". It just sets over the manifold and guides the exhaust up and away. Its not a sealed exhaust pipe. I'm hoping the exhaust velocity actually sucks air into those holes rather than letting exhaust out. I didn't start the engine, just barely had time to weld and RUN!
441713d1443071064-welded-rusty-22ga-exhaust-mig-cat_exh_13-jpg
441714d1443071064-welded-rusty-22ga-exhaust-mig-cat_exh_15-jpg
/ Welded a Cat 650 Dozer stack (MIG) #3
Well, your plan was good, but you didnt finish the job. You should have welded up the slits because thats where the exhaust is going to blow out I think. Also, if the dozer sets outside in the weather, thats where rain water is going to run into the engine.
/ Welded a Cat 650 Dozer stack (MIG) #4
I gotta ask why?
That pipe and that condition, Id just run to the local muffler shop and get a piece of pipe for $20 and get them to flare it. By the time you figure in gas and wire and other consumables, you spent that much at least, plus as pointed out, the job isnt finished, water will get in through the cuts and exhaust will blow out from them.
Now if this was done "for fun"... just weld up the cuts and call it good.
If this welding job makes the operator happy doing work for me, I'm happy. I have him for a couple days. If he wants to bring me the proper materials to repair it I'll put it in. He has FOUR of these 650Gs, with 6-way (?) blade, doesn't use them, won't sell any. Not that I need to own one just seems a shame they are sitting.
Exh manifold (on the engine below) has appx 3" diameter vertical stack. When you set the "hood" down, this 5" diameter cone drops over the 3" stack, there is an inch of space all around. I suspect to allow for flex that would otherwise break the exhaust manifold. Above the hood it reduces to 4" stack. Can't weld up the slits, I'd be there all day. I suspect that its been wrapped with coffeecans for 10 years, which probably didn't seal all that great.
/ Welded a Cat 650 Dozer stack (MIG) #6
Just for future reference, they do make a carbon backer that you can lay behind that thin metal. Weld wont stick to it and it would allow you to weld those slits up in one pass. At work we use those backers to weld up, (mig and stick), switch and frog points where you have to build up the wear and still retain the original shapes. It makes for easier grinding. Should work equally as well for thin sheet metal.
/ Welded a Cat 650 Dozer stack (MIG) #7
I gotta ask why?
Ditto. That is going to be miserable to run with the exhaust coming out of the holes.
Carbon backer that's interesting. I see copper welding backers on eBay but none are carbon.
I guess we'll see if exhaust comes out or air sucks in. Maybe we should take bets. :D
I've drawn the inner pipe as it should be, but in reality it's about half gone, doesn't extend up to the cone anymore. Further repair is outside my job description for the moment. But if he wants to reduce my dozer rental charge its something I can do that he can't,,,,,,
/ Welded a Cat 650 Dozer stack (MIG) #9
I just got thru talking to the welder at work about those carbon backers. They are in fact pure carbon. I was trying to find the proper name so I could look them up but he said he always just called them carbon backers. He orders them out of the company material catalog with a part number that doesnt mean anything outside the company. I'll have to do a little more investigation to see if I can find the commercial name for the product.
That sounds like a useful item. Does copper work too? I have copper.
/ Welded a Cat 650 Dozer stack (MIG) #11
Yes copper will work, aluminum and brass too. They also make a aluminum backer tape you can use as a backer or in the place of a purge gas if you ever get around to buying a tig and want to tig some stainless. The tape in place of purge can be really handy if you are welding large volume stainless parts that would be hard to purge with argon (like a gas tank for example), and dont want it to oxidize and rust
Does that aluminum duct tape work? Seems like the glue would flame on,,,,but it it excludes oxygen then it's all good, right?
/ Welded a Cat 650 Dozer stack (MIG) #13
you could use some tig wire, maybe 1/8 inch ? ( dont know how be the gaps are ) put the tig wire in the gap to fill it then mig the gap closed. move on to the next one
/ Welded a Cat 650 Dozer stack (MIG) #14
You could run down to Home Depot, or Lowes buy their cheapest DC stick welder, and a Tig rig, and made quick work of that project.;)
/ Welded a Cat 650 Dozer stack (MIG) #15
This guy doesn't have the name of Mike R........... does he?
The guy could at least store one at my place where I'd promise to run it a couple hours every few months. Not Mike R.
Already made quick work of it. :D And Home Depot is a 3 hr roundtrip.
However,,,,,
My Multimatic 200 is a MIG/TIG/Stick. All I need is the MILLER 301287 TIG FOOT CONTROL CONTRACTOR KIT FOR MULTIMATIC 200, and maybe a kick in the pants to order the stuff! Anybody have opinions whether $385 is a good price? Or should I peice it together with separates. I'd want it to plug into my machine. Also need an argon bottle. And some time to learn it.
441764d1443154908-welded-cat-650-dozer-stack-miller301287-jpg
/ Welded a Cat 650 Dozer stack (MIG) #17
The guy could at least store one at my place where I'd promise to run it a couple hours every few months. Not Mike R. Already made quick work of it. :D And Home Depot is a 3 hr roundtrip. However,,,,, My Multimatic 200 is a MIG/TIG/Stick. All I need is the MILLER 301287 TIG FOOT CONTROL CONTRACTOR KIT FOR MULTIMATIC 200, and maybe a kick in the pants to order the stuff! Anybody have opinions whether $385 is a good price? Or should I peice it together with separates. I'd want it to plug into my machine. Also need an argon bottle. And some time to learn it.
The price is good.
Before others chime in about being cheaper to piece one together keep in mind this kit has the (small) flo thru Dinse connector. A pedal from Miller or SSC will be $150-250.
Yes, you can hook up the torch other ways but Sodo's machine already has a solenoid and any other configuration would just be cumbersome. But I'm kinda picky that way. Terry
/ Welded a Cat 650 Dozer stack (MIG) #20
The aluminum backer tape isnt just a strip of aluminum with glue. It also has some insulation, fiberglass I believe, in the center of the tape. The glue is only on the edges of the tape. The fiberglass insulation provide support to keep the weld from dripping thru. I have never used it, just know that its available.
Cant wait till you get your tig setup, you just might give me the motivation I need to really start practicing. My tig skills are terrible at best. Steel and aluminum I can do so so, but thin stainless gives me fits. I was never any good with gas welding either, Now that I think about it, I really aint that good with stick or mig. I might need to book a flight and visit Shield for a day or two.
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
WHIRLPOOL REFRIGERATOR/FREEZER W/ICE MAKER (A64281)
WHIRLPOOL...
2023 Freightliner Cascadia 116 S/A Day Cab Truck Tractor (A61573)
2023 Freightliner...
Trimble EZ Guide 500 Monitor (A63117)
Trimble EZ Guide...
UNUSED KUBOTA 48" PIN ON BUCKET (A64280)
UNUSED KUBOTA 48"...
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
