Welcome to my Nightmare!!!!
/ Welcome to my Nightmare!!!!
It rained 2 inches last night and this morning, so it's too muddy for doing allot of things.
I don't know what the head weighs, but I'm guessing it's gonna be heavy and not something I want to be picking up and carrying off the dozer by hand.
The front loader on my backhoe is plenty strong to pick it up, but the bucket is too wide to get over it without having to take off the cage. The hooks are also on the top of the bucket and when I lift it up high enough to get the head, I'm blinded by the bucket.
My solution was to mount the top part of my cherry picker to the side of my bucket. Three grade five bolts should be plenty strong to hole it in place and it even has a handy hook at the end for lifting off the head.
Eddie
/ Welcome to my Nightmare!!!! #22
Regarding the oil/grease buildup on radiator... When my JCB was down, I used what I think was called "The purple stuff" or perhaps Purple Cleaner.
Kind of irritated your hands a bit when it got on bare skin but evidently it's a pretty strong grease cutter. I sprayed it on and hosed it off (with no scrubbing by me at all, simply soaking) and I think it did a great job.
Probably other degreasers out there just as good or better, that was my one experience.
Good luck with your project.
/ Welcome to my Nightmare!!!! #23
Eddie,
The best thing to clean non-aluminum radiators is oven cleaner. Spray it on and wait about 5 minutes, then wash it off. I always us the cheap stuff for a buck at the Dollar Store. It works just as good as the expensive stuff. BTW, on the deal about pulling the piston out the bottom. Some engines you can take the rod cap off, put rubber tubes over the rod bolts and then rotate the crank throw out of the way. Then you can take the piston out. I don't know if you can on that engine or not.
/ Welcome to my Nightmare!!!! #24
Eddie,
I've been trying not to recomend letting Steph do it... /forums/images/graemlins/grin.gifBut I just couldnt resist, it seems she can do everything else......
Anyhow, as for de-torquing, a good rule of thumb would be to start on the outer edges and work evenly toward center.. Some recomend, cracking each bolt loose then returning to take them the remainder of the way out.. Either way, you should be safe with a cast iron head.. Make sure you get the correct Tq setting and find out if you may need to replace the head bolts.. Some are Tq to yield(but thats usually on auto stuff)..
Really, it looks like you have it licked.. just gota get it done... /forums/images/graemlins/grin.gif
I'm trying to find out the torque and tightening sequence to put the head back on. Also the connecting rods.
Anybody know of a webiste that lists this?
I've also never replaced or seen a cylinder sleever pulled or replaced. Is there a website that has this infromation?
Thank you,
Eddie
/ Welcome to my Nightmare!!!! #26
</font><font color="blue" class="small">( I've also never replaced or seen a cylinder sleever pulled or replaced )</font>
Me, neither, but my brothers have told me you do it just like ScottAR said; freeze the sleeve and have the block warm and it goes in easy (or so I've heard). /forums/images/graemlins/wink.gif
I doubt that I'll ever have to do the job you're doing, but I'm enjoying reading about it and seeing the pictures.
Thanks Bird,
I've found a really good website called www.tpub.com that gives step by step directions on how to pull each part of the engine apart and put, check it out, and put it back together.
It has all the torque specifications and sequenses.
Did you know theres three steps to torquing down the head and two sequenses?
I've also read about how to pull the cylinder sleep and that I need a Universal Sleeve Puller to do this. The tool costs $650 to $700 plus shipping. /forums/images/graemlins/shocked.gif
I've added to my list of things to do is find a place I can rent one!!!!
They also mention that I need to heat the pistons to 130 degrees and the pins need to be 65 degrees to fit together!!
Eddie
/ Welcome to my Nightmare!!!! #28
That looks like a pretty clever solution /forums/images/graemlins/cool.gif
Don't you guys have a decent radiator shop nearby ? Just get the whole thing dipped and cleaned (inside and out) . Should be reasonably inexpensive also.
On another positive note, the inside of the block looks nice and clean.
/ Welcome to my Nightmare!!!! #29
When you clean that radiator out be prepared for a huge increase in air movement. My fan roared and blew all kinds of dust when before a radiator cleaning it just spun. Of course mine needed cleaning pretty badly.
Worst nightmare is right. Everything about a dozer is great except when it breaks.
/ Welcome to my Nightmare!!!! #30
Eddie, you probably already have found this site, but in case you haven't, there are really literate people there regarding dozers, crawlers, etc. The big International crawlers all had wet sleeves. I'm sure you can find someone there that's "Been there, done that, and got the T-Shirt" as well for your dozer. Good luck. PS on the head. I was a 19 year old diesel mech when I had to pull the head on a 6-71 GM (earthmover engine). Head weighs in the neiborhood of 250 lbs. or more. We pulled the head, dropped the pan (about 28 bolts on the 2 part pan) Popped the rod cap replaced the injector (it was what put the hole in the top of the piston) new piston/sleeve and back to work in a day. Had never done it before and haven't since (thankfully), but you WILL need a crane of sorts to lift the head. Good luck! BobG in VA
http://www.ytmag.com/crawlers/wwwboard1.html
Thanks guys for the help and suggestions.
I've been getting kind of ahead of myself searching for answers to problems I'm no where near to yet.
Today I've spent the last several hours tyring to figure out how to get the injector nozzles out. Any suggestions?
It's a Bosch fuel injector and from what I can tell, it looks like they are just pressed in. The picture shows the notches on either side that a clamp went around to hold it down. A bolt through the clamp held pulled the injector down and kept it tight.
Now that the clamp is off, I have an injector with two notches on either side. I tried a wrench to see if it would turn or break free, but I'm also afread of doing some permanent damage.
Does it just pull out? How do you pull it?
Thank you,
Eddie
/ Welcome to my Nightmare!!!! #32
Eddie,
I know absolutely NOTHING about engines, diesel or otherwise. I had the idea of replying with a smart aleck answer - use an injector puller. Then, I went to Google to see if somewhere in that smart aleck idea there might be a thread of truth. All I can say is that there are diesel injector pullers out there. Whether or not there is one for your dozer or if yours would be removed with a puller, I haven't a clue. But give it a try. You never know.
/ Welcome to my Nightmare!!!! #33
There should be a "special tool" to "pry" the injector out. We had one when we did the 6-71. As well as I remember, it resembled a claw to pull nails out of a board but bigger......Check with Case, they should have one they can loan you....BobG in VA
/ Welcome to my Nightmare!!!! #34
Some you can get out with a heel bar. Some take a slide hammer that screws onto line fitting. That looks to be slide hammer type, but I don't want to steer you wrong because I'm not familiar with that particular engine, mostly much larger ones.
/ Welcome to my Nightmare!!!! #35
A slide hammer or light prybar for a 5.9 (Dodge) Cummins,if that is any help?
/ Welcome to my Nightmare!!!! #36
</font><font color="blue" class="small">( Eddie,
I know absolutely NOTHING about engines, diesel or otherwise. I had the idea of replying with a smart aleck answer - use an injector puller. Then, I went to Google to see if somewhere in that smart aleck idea there might be a thread of truth. All I can say is that there are diesel injector pullers out there. Whether or not there is one for your dozer or if yours would be removed with a puller, I haven't a clue. But give it a try. You never know. )</font>
You were right. Cummins use a slide hammer type "injector puller" cj140
Now, someone might be able to make one cheaper by fabricating a metric nut "coupling" to a regular slide hammer. Or a piece of rod with a sliding weight welded to a metric nut.
/ Welcome to my Nightmare!!!! #37
Pipe nipple and a lug nut.
Seriously. The lug nuts on a Dodge truck are the same thread that is on the injector lines. Put the proper length pipe nipple over the injector and thread the lug nut on the end and it will jack the injector right out.
(I knew I saw it somewhere. Issue 52 of the Turbo Diesel Register.)
/ Welcome to my Nightmare!!!! #38
</font><font color="blue" class="small">( Pipe nipple and a lug nut.
(I knew I saw it somewhere. Issue 52 of the Turbo Diesel Register.) )</font>
Great tip.
/ Welcome to my Nightmare!!!! #39
That is the greatest thing I've heard in a long time. It's like a true eureka moment. That guy needs a beer, you know the guy that couldn't figure out how to get the injector out so he just started looking around until a light bulb went on.
/ Welcome to my Nightmare!!!! #40
</font><font color="blue" class="small">( That is the greatest thing I've heard in a long time. It's like a true eureka moment. That guy needs a beer, you know the guy that couldn't figure out how to get the injector out so he just started looking around until a light bulb went on. )</font>
It's like the old saying about the 3 different people you want on a team. You want a really smart guy, that can do the math and solve equations. You want a really strong dumb guy, who will do the heavy lifting without asking questions. And you want the laziest guy you can find, because he'll always find an easier way to do it. /forums/images/graemlins/grin.gif
