Welcome to my Nightmare!!!!
/ Welcome to my Nightmare!!!! #341
Eddie:
How about posting a link to your next thread at the end of this one?
I really enjoy reading about your projects and don't want to miss out.
The search function to look for posts by a specific person doesn't work for me.
Thanks,
Dave
/ Welcome to my Nightmare!!!! #342
Eddie:
Thanks,
Dave
/ Welcome to my Nightmare!!!! #343
</font><font color="blue" class="small">( " ... My oil preasure is lower now than before the rebuild, so that's a concern, ...")</font>
What was it, and what is it now?
/ Welcome to my Nightmare!!!! #344
/ Welcome to my Nightmare!!!! #345
Maybe the old turbo caused the higher oil pressure which might have been the start cause of the trouble ?
By the way, congrats on your dozer running again... I know that feeling, Whether its my Zetor or my Volvo car, it allways keeps me awake at night if something isnt running and i need it to work.... /forums/images/graemlins/crazy.gif
/ Welcome to my Nightmare!!!! #346
Before the rebuild I put a mechanical oil preasure guage on the engine and had 60 pounds at full throttle, and 30 pounds at idle.
Now I have 35 pounds at full throttle and 15 pounds at idle.
Is this bad????
Thanks,
Eddie
Is this bad????
Thanks,
Eddie
/ Welcome to my Nightmare!!!! #349
Uh, Bad? Sort of, but not too awful bad. Well, for a new rebuild, it is lower than you would expect to see. Just did a Ford and it now has 80 psi cold - 70 hot and 55 hot idle.
Did you by chance measure the clearance between the crank and the main and rod bearings? Use of plastigage, snap guage or similar. If so, what did you get? If not, you may want to. Those clearances are what dictate your oil pressure.
Did you put in a new oil pump? The relief spring may be too weak. A washer under the spring may solve the problem.
jb
/ Welcome to my Nightmare!!!! #350
jb
/ Welcome to my Nightmare!!!! #351
Eddie, you need to investigate this, that's quite a bit of a change, and I agree that the pump, and crank should have been checked. Manufactures also make rod bearing a bit oversized by a .001", and also .0015" just for a good crank that's a bit worn undersized. I installed new standard sized rod bearing in my IH3444, with new oil pump gears, and also did the shim for the relief spring. The crank was fine, but worn undersized .001" on two outer journals, and .0015" on the two inner journals. The factory manual states that 35psi is fine, but mine now has 45psi, hot, and I'm fine with that. What does the Cummings diesel handbook state? What oil weight are you using for break in? Did you run a straight weight oil for the older engine?
/ Welcome to my Nightmare!!!! #352
/ Welcome to my Nightmare!!!! #353
Generally speaking... you need 10 psi for every thousand RPMs. You're numbers are quite a drop though. As mentioned before... what oil are you running? Same thing as usual?
/ Welcome to my Nightmare!!!! #354
/ Welcome to my Nightmare!!!! #355
The first thing I would check is the gauge itself.
The odds are that it is OK, but checking it is cheap and easy compared to anything else.
Also, what grade & type of oil did you put in? Is it possible it got diluted with diesel at all in your starting attempts? This would lower viscosity and oil pressure.
/ Welcome to my Nightmare!!!! #356
/ Welcome to my Nightmare!!!! #357
Do you still have your old rod and main inserts laying around? If you do look on the back side of them and see if there is a "std" or ".010" stamped in them.
/ Welcome to my Nightmare!!!! #358
/ Welcome to my Nightmare!!!! #359
Don't want to hijack Eddie's post but I have a related question. After seeing Eddie basically gut this engine and rebuild I am thinking of doing the same thing on a 560 International Gas. Aside from what Eddie had to do and the differences between gas and diesel is the overhaul pretty much the same? The 560 has wet sleeves as well. I found an in frame kit complete with sleeves for $530, and if that's all it is, I might go for it.
Go Eddie Go! Its been great following this thread! Looking forward to the creating a lake thread continuing!
/ Welcome to my Nightmare!!!! #360
