weird hydraulic problem
/ weird hydraulic problem #1
reubenT
Spencer TN
JD 2010 Kubota B6200
New Holland 555 skid steer, late 80's model. I got it about 2 years ago cheap with dead engine, got the engine rebuilt but due to busy schedule havn't got around to getting all the other little issues worked out. Lately I have a break from other duties and it's time to get it going and start putting in orchard/garden fencing. It's all working now except the hydraulic valve for the front end loader. The main lift works fine, but the tilt refused to work. After sitting awhile it does about 1/4 stroke and stops. Like something leaks down while sitting. I have had everything apart and checked out. Valve seems to work properly on air when it was out. Put it back in and tilt still will not work. Then I discovered that if the lift side of the valve is operating at the same time as tilt that the tilt then works. Simple enough system, but it sure is acting odd. Just a standard double spool loader valve. Has 2 return outlets, one runs through to an accessory valve when both spools are in neutral, the other dumps oil back to reservoir when either spool is used. It's like the oil return is blocked off on the tilt side spool when the lift side is in neutral position. But it was not blocked when valve was out and blowing air through the passages with air compressor. And there's a check valve on each spool on the inlet side, preventing back flow from cylinder to inlet.
Well. Been messing with it for days and suddenly got an idea the accessory valve may be stuck off from neutral position. Sure enough. It was stuck. Got it feed up and loader works properly now.
/ weird hydraulic problem #3
Isn't it a great feeling when you answer your own question and fix something that has been eluding you.
Nice work.
I wish I could get my M-F 231 hydraulic top link to work... maybe if I just think about it like you did, it'll come to me.
/ weird hydraulic problem #4
IMO...That is exactly what you did when you posted the question about leaving a 3ph implement in a raised position...RickB's response was spot on so I didn't reply to that thread..
John Deere 4840 Tractor (A66285)
John Deere 4840...
2018 Generac S/A Towable Light Tower (A64194)
2018 Generac S/A...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
2022 EZ-GO ELITE...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
